Question about Vacuums
Rival Beverage Fountain does not flow. Could it be an internal motor problem? Lights work
Vax stopped mid vacuuming,as though fuse in plug has blown.checked fuse,OK.no lights lit.vax not working.
Most vacuums have thermal protection on the motor that will shut it off if it gets too hot. If you can turn it off, wait 10-15 minutes, and it works when you turn it back on, that's what is going on. Now, the motor shouldn't normally get that hot, so your next challenge is finding out why. Check for any blockages in the air flow or cooling vents, and if the motor also powers something like a beater bar, make certain that it turns relatively freely.
Feb 02, 2016 | Vax Vacuums
Windsor sensor vacuum lights flashing then motor shuts off
I've worked on these a lot. What I think you're explaining is the bypass flow switch which is a common failure. It's located in the base inside the auction side of motor housing...
May 01, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
Why won't my Rival vacuum sealer vacuum?. It just hums when I push the vacuum button.
see the next steps and follow with common sense: God bless you
If the noise is coming from the motor area it may be a broken fan blade, if it's broken replace it. If the noise is coming from the brush area then it may be a defective brushroller bearing or brushroller, if either is defective it needs to be replaced.
Inspect a) power cord b) outlet wall c) thermal FUSE very important.d) see any debris see diagram attached.
Jul 27, 2012 | Vacuums
I've got the Hoover #uh70035b, it worked great for a long time, but now after about 5-10 mins it then shuts down and after a "long" while it will work again. It's like it's over...
go to hover for the owners manual sounds like it might be a clogged internal filter stifling the normal flow of cooling air around the motor
Dec 09, 2017 | Hoover Vacuums
How much chocolate is needed for a cookworks chocolate fountain
http://www.koolatron.com/manuals/WTF-43E%20Choc.%20Ftn%20Double%20Tower%20Manual.pdf this is the only thing I could locate, there are reviews on your machine but none told of a limit or amount, they all did say however to add a little oil to the choc as it helps the flow and you cant taste it
May 18, 2011 | Vacuums
Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Feb 22, 2011 | Vacuums
Instructions to CFF-986 chocolate fountain doesn't say how much melted chocolate to use. Also, is there a certain kind that is best to use?
It holds up to 3 pounds of melted chocolate, There is no certain brand of chocolate that works best but you will find that the smaller chocalate chips melt better and you will also need to add a little vegetable oil to keep it flowing properly.
Aug 26, 2010 | Vacuums
Hoover just cut out while we were vacuuming the floor, no power, is there an internal fuse somewhere?
No. there is a thermal fuse that will reset after the motor cools down. Check for blockage and clean filters and clean the cone assembly for proper air flow.
Sep 28, 2009 | Hoover WindTunnel Cyclonic HEPA Bagless...
Water spews out of flow indicator
yes you can buy just the cap go to bissell's website and you should be able to order it yourself, it just screws off and on.
Sep 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
77 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
