Question about Refrigerators
GE refrigerator model DSS25KSRD water deposit at refrigerator bottom
  • 12 Answers
SOURCE: GE Bottom refrigerator/MOdel GS18LCRABB
I can only wonder if the drain tube has been cleaned out to make sure water flows into the pan .Also make sure it is fully defrosted and left over water will freeze quick.
Eeggman
Posted on Mar 10, 2008
Maytag317
  • 1136 Answers
SOURCE: Water in Bottom of Refrigerator/How disconnect icemaker
Hi, Remove the ice maker by loosening the screws that hold it to the wall. Once it is loose, there is enough wire that you can unplug the icemaker and set it aside. Now remove the rear panel and you can unplug the drain. Be sure and flush hot water through the drain to be sure it is oen.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on May 23, 2009
woodchuck789
  • 4070 Answers
SOURCE: Water collects under the produce bins at the bottom and leaks out
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Posted on Oct 11, 2009
aasc
  • 1606 Answers
SOURCE: DSS25KSRD SS GE Adora refrigerator- ice in tray
It sounds like the # 4 thermistor is bad . You will have to remove the lower inside rear freezer panel ( 2 or 4 screws ) and on the top of the coils , you will see a 1 " long torpedo looking piece , clipped on , with 2 white wires going to it . Part number WR55X10025 . This thermistor , tells the maon control board , the temperature of the freezer coils ( evaporator ) and when to defrost and when to stop defrosting and turn the compressor back on . There is also a defrost thermostat which cuts the heater off to keep from over heating , but I do not believe this is part of your problem . You should also replace the # 5 thermistor , located behind the oval grill , mounted on the lower right side of the freezer . This thermistor , tells the main control board , the temperature of the freezer section .
Posted on Oct 21, 2009
arikrom
  • 528 Answers
SOURCE: water in bottom of refrigerator
your freezer cabinet need to get all out ,and open the back wall there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com
Posted on Jan 04, 2010
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water leak onto floor
There should be a drain pan that is deposited into, however some will crack or be moved out of place causing this.
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
Icemaker on hotpoint refrigerator model no. hss25gftcww makes ice slow and not as much
have you changed the filter? if so try a complete defrost of machine and pull the inlet line from back of icemaker and make sure there is no calcium lime deposits restricting water flow
Jul 04, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
I have a GE Refrigerator PCF23MGWCC the water dispenser tube on the outside front has a hard yellow substance on the end of the tube. I don't know what it is or how to get the tube out to clean it.
it sounds like you have mineral deposits in the tube, from hard water. you can try using and oxidizing cleaner such as Oxy clean or some other mineral dissolving solution.
Mar 13, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Eeggman
Feb 18, 2008 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
