Question about Nikon D200 Body Only Digital Camera
My d200 is picky about when auto focus works. It won't work for the shot I want, but if I turn the camera 8 degrees and try at that angle, it works fine. Sometimes turning the camera to manual, then off, then on, then back to auto focus does the trick, but not always. What is going on?
  • 3,083 Answers
The focus ring inside the camera is a free-spinning lens that is controlled by electromagnets, with feedback from the microprocessor and sensor. When some dust, lint, sand, or dirt works it's way into the lens assembly, the ring can hang up, which is probably what's happening in your case. You can try to blow out the lens assembly with compressed air ($4 at Walmart) to see if you can free it up. If this doesn't work, you will have to have it serviced. You can try to gently bump the camera to free it up, also.
Take it into a local repair shop for an estimate, or contact Nikon Support on the web.
Good luck, and hope this helps.
Posted on Apr 11, 2011
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus problems using 18-200mm lens on D200
Your lens might need to be recalibrated. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Sep 28, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon 18-200 mm vr lens not auto focusing on my nikon d200
lets start with the basics, try hard reseting it and try again, if that doesnt work then
try upgrading your firmware (if possible on your camera) and if that doesnt work then it may be the lens, but dont forget to spend a few hours trying to find a option for it in the meny
Jun 13, 2009 | Nikon D200 Digital Camera with 18-200mm...
I have a Nikon D200 camera. It's now 2 years old and I'm having difficulty with the auto focus. The camera focuses but it comes in and out and I have to depress the shutter several times to get it clear....
the auto focus works on the basis of contrast. If you aim your chosen auto focus square at an item that fills that square with only one color or shade of color light a blank wall or a solid blue sky the camera can't focus because it is trying to compare the contrast in order to focus the camera. try to make sure that you choose an item with contrast to aim your auto focus square on like someones eye and part of their cheek so the camera can see somre contrast to evaluate then focus. Obviously you depress your shutter half way to activate the auto focus let the camera do its thing keeping the shutter half way depressed move your field of vision to where you want it then fully depress the shutter to take the picture. the camera relys on seeing some contrast within your autofocus square in order to auto focus
Jan 14, 2009 | Nikon D200 Body Only Digital Camera
Nikon D200 refuses to auto focus with any lens it just doesn't do anything.
Does the camera body has a M/AFswitch? it would be located in front on the left side if that accidently gets changed to M your lens will not AF any more until you change it?? I know it sounds so simple but who knows!! Barry Brown
www.coralreefphotos.com
Oct 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Auto Focus
It seems to be a problem with the internal working of the camera its self. I have requested a replacement fro my seller. Thank You Samuel
Apr 06, 2008 | Nikon Cameras
Trouble auto focusing
If it's any consolation, I have the same setup and the same problem. I'm now at the point where I'm probably going to have to return the lens as faulty, but there are a few things it could be on yours which you might want to check.
Have you got the D200 set to auto-focus? The selector (on the front of the camera, on the lower left) should be in the S position (as opposed to C or M).
Have you got the lens set to auto-focus? It should be in the M/A position, rather than M.
Have you tried cleaning the contacts? Pop the lens off and give the contacts a clean with the appropriate equipment. Dust on the contacts could be causing a problem.
Failing that, have you tried turning the camera on and off a few times?
I've obviously tried all the above on mine, and now suspect I've got a faulty lens that needs fixing ... which really sucks! Good luck with it, let me know if you get it working.
Dan
Jan 20, 2008 | Nikon D200 Digital Camera with 18-200mm...
Auto Focus Problem
Way to check settings is to take the batteries out for a while, it should revert to factory default settings. I tell a lot of People to try this, it works an amazing number of times. Auto focus looks for vertical lines, what are You shooting at? Try rotating the camera 90 degrees, if it locks better,Bingo. Subjects without much contrast are hard to lock focus on
Sep 12, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Nikon D200 Body Only Digital Camera Logo
22 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
