Question about Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers
Hi. I just installed my Linksys E200 Advanced Wireless router and I can't get the wireless connection until I have the information to answer this question: A username and password are being requested by http://192.168.1.1. The site says: "Linksys E2000" Can you help?
  • 1,591 Answers
Login is admin
there is no password, just enter the username (admin) and leave the password blank and hit OK
Posted on Apr 11, 2011
Escribe your Linksys E2000 Advanced WirelessN Broadband Router Network Routers Problem Router has been working fine since initial setup almost a year ago. Turned on computer yesterday, and it would not...
Please check whether your computer's wireless connection enabled or disabled. If you are using windows 7 this information you can find in network sharing center. By accident if WLAN is disabled it can be enabled. Also power cycling the router may do the trick.
More drastic approach is resetting the router which I recommend to reserve as last resort. With information you provided the router seems to be fine and your computer wireless need to be enabled!
good luck!
Sep 12, 2011 | Cisco Linksys E2000 Advanced WirelessN...
Cannot access my wireless router because i had my computer cleaned and cannot find my disc to install my wireless system again
IF you don't know your wireless password then you can reset your router. To do this press the reset button which is located in the back of your router(press untill all lights start blinking)
Connect your computer in any 1-4 port
After that you can access your router via web browser. For most Linksys routers you can achive this by typing : 192.168.1.1 default user: admin pass: admin
Then you can find the Wireless tab and configure your new Wireless Network Name and password
Dec 15, 2010 | Linksys Wireless-G Broadband Router
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
Wireless g notebook adapter
Hi sfconagelo,
Which card; wired or wireless card? Check to make sure that the card is properly installed in your computer in device manager. If properly installed then you should be able to connect but not if your Linksys router has wireless encryption (for wireless card).
Regards,
Angel
Jul 08, 2010 | Linksys Wireless-G WRT54G Router
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Nov 12, 2009 | Linksys Wireless-G Broadband Router
I have a wireless G linksys router not connected with laptop?
  • First, try unplugging the router and pluggin git back in. Frequently that solves the problem.
  • Second, if that doesn't work, there should be a reset button on the back of the router. Again, hit the button and wait.
  • The more advanced option it to use the web utility the route has. You should be able to access it by going to the router's IP address.
IMPORTANT: If you don't know anything about routers you can cause yourself some serious problems in the utility. Most of the settings should remain at their default setting. If in doubt...Leave it be.
  • Ok, disclaimer over. The router IP should be something like 192.168.1.1 (that's the common one used for linksys routers.) If you aren't sure, hover over the icon on the bottom right of the menu bar of your Dell and it should tell you the IP of the connection. You hould be able to access the router by taking off the last number and adding a 1 instead. (ie...your number is 555.555.5.3, you type in 555.555.5.1 into the address bar of your browser.)
  • You will have to type in a user name (linksys) and a password (admin). If you have changed the username or password, then you are a more advanced user and have probably already tried this. Either way there will be a tab in the utility for wireless information.
  • Here you can see a great deal of information about your wireless settings. You could also try using the one touch set-up option if your router hass it in the utility.
  • Lastly, make sure you have the most recent firmware (that's the software installed on the router itself.)
  • You should be able to go to the linksys website and download the newest one. The nice thing is that they give you great instructions on how to install it and get the router running again afterward.
GOOD LUCK!!
Jan 02, 2009 | Linksys Wireless-G WRT54G Router
WRT54G Linksys Wireless Router
Hi and welcome to FixYa,
Pinging most LinkSys WRT54G would require to open a command prompt in the PC, type "ping 192.168.1.1" less the quotes and await reply from the router.
Good luck and Thank you for using FixYa.
Dec 03, 2008 | Linksys Wireless-G WRT54G Router
My lap top connecting to my wireless system.
Your computer is not yet connected to the wireless network of the router. Also, make sure that your wireless computer has a wireless adapter installed on it. You may verify it on the Device Manager. If you're using a laptop with built in wireless adapter , make sure that the switch for the wireless connection is on so that it will detect the signal of the router.
Try configuring or verifying the wireless settings of the router first by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4585&p_created=1165894972&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAwNiZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aXJlbGVzcyBzZWN1cml0eQ**&p_li=&p_topview=1
After configuring or verifying the wireless settings of the router, connect your wireless computer by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_created=1160185039&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAyNSZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jb25uZWN0aW5n&p_li=&p_topview=1
If you cannot still connect wirelessly, let me know of the following:
- model number of the router
- operating system of the computer
- wireless adapter installed on the computer (built in or external)
- brand of wireless adapter installed
- wireless settings of the router (SSID, wireless security)
May 13, 2008 | Linksys Wireless-G WRT54G Router
Win98, Linksys USB Adapter, 2wire router... no internet
hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Apr 16, 2008 | 2wire (1000-400108-001) Router
Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers Logo
473 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
