Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA r56wh78 rear projection screen is blurry
We got the TV, and the screen wasnt working. now we have color, but the picture is REALLY blurry. how do we fix the focus on the TV?
  • missniki07 Nov 28, 2008
    it is blurry a round the sides of the t.v screen
    New Friend:
  • 50 Answers
If you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
Posted on Aug 11, 2008
It is blurry a round the side of the screen
Posted on Nov 28, 2008
I have the same model and the same problem - the picture just started getting slightly blurry, and moving objects get sort of grainy and jagged around the edges. I'd like to try the flyback adjustment you mention, but I have no idea what to look for. Is there a guide or reference that could help with this stuff? Schematics?
Posted on Oct 08, 2008
SOURCE:
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Rca projection tv is blurry
Hi, you need a tv tech, G2 focus block and pincushion circuit are what your describing, these are both related to the high voltage circuit but are 2 different circuits, definitely not a layperson repair, do yourself a favor and call a tech on this one, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca projection
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Jan 04, 2008 | RCA P52926 52" Rear Projection Television
BLURRY SCREEN
What do the colors look like? Does it look like you have more than one image, and the trailing edge of the second image is in a primary color like red or blue??
Bill
Dec 01, 2007 | RCA P52926 52" Rear Projection Television
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
RCA 46" Rear Projection TV - Picture is Blurry and RED
That sounds like the screen and focus controls you are adjusting. It sounds like you have a bad HV Splitter inside the TV. #205064 or #204809 Depending on your model number. http://www.matelectronics.com/acatalog/Mat_Electronics_Replacement_Parts___TV_134.html sells them for about 20 bucks.
Dec 27, 2006 | RCA P46812BL 46" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
761 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
