Question about Linksys Computers & Internet
Want to reset to factory settings on my Wireless G 2.4 GHz broadband router
    President:
  • 2,187 Answers
You can do that by accessing the router's setup page on 192.168.1.1 or you may want to use a pin and use it to press the reset button for more than 1 min. If that does not work at the 1min mark, keep holding the reset button while unplugging the power and putting it back in.
Posted on Apr 11, 2011
I have a Linksys Wireless-G 2.4 GHz Broadband router. My daughter forgot her pass word as she used it while in college. I know little to nothing about computer technology. How do I reset and connect the...
If you go to the back of the router youwill see a reset button press and hold it for 30 sec.then unplug the router and wait 15sec. and plug it back in this will set it to factory settings you can access the router by adding 192.168.1.1. and the user name is blank and the pass word is admin all lower case then you will be able to access the router and set it up for your needs
Oct 13, 2011 | Linksys Wireless-G Broadband Router
I forgot my pass word and want to change it. My daughter put in her security pass word and can't remember it for a wireless-G 2.4 GHz Broadband rouuter.
Hello
You can do a factory reset.
1 unplug all cables to router.
2 Hold down small reset button behind router,use a pen tip to hold this button in for 30 seconds.
3 Reconnect cables,power cable first.
4 Log into router using default password and username.Which should be......
username=admin
password=password or admin
Once loged in you can reset your username and password to what you want.
How to set up The wireless G 2.4 GHz broadband router linksys?
Plug a computer into the router. Open your web browser and in the address bar type 192.168.1.1 or 192.168.0.1 If the router is fresh from the factory the login will be admin and the password will be password This should get you into the configuration for the router.. from there look on the left side of the web page and you will find config options for all aspects of the router.
Apr 14, 2011 | Linksys Wireless-G Broadband Router
RE INSTALL 2.4 GHz WIRELESS-G BROADBAND ROUTER .CANNOT RECALL PASSWORD CANNOT COMPLETE SET UP>?????? JERRY HELP. jerry.morey@sbcglobal.net
Perform a hard reset by inserting a paperclip into the reset hole while powering up. To access the router use address http://192.168.1.1
On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin".
Mar 05, 2011 | Linksys Wireless-G Broadband Router
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
I have a linsky wireless G 2.4 Ghz 54Mbps (model WRT 54G) I have the cd, but I do not have the password. I am not sure if this is the reason, I can't set up my network. How do I get another password
Linksys WL router always has default password "admin" you will have to reset router to factory defaults by plugging Pin in to Tiny Hole on Router back side for 5 seconds. and then login by default ID "admin" and password "admin" to configure router again. [Remove Inverted Commms from User name password while entering
Mar 09, 2010 | Linksys Wireless-G Broadband Router
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
Describe your linksys wireless g 2.4 ghz broadband router troubleshooting Problem: I have had this hooked up for a couple years now as a secured network, all of a sudded one night it said it was unsecured...
your router might be resetted automatically.
You will need to check the wireless settings of the router.
that computer.
Click here for step by step instructions
Jan 12, 2010 | Linksys Wireless-G Broadband Router
Linksys wireless -G 2.4 GHz router just stopped
I would try a factory reset of the router if there are not any special settings saved in the router. To factory reset the router press and hold down the reset button on the back with a pen or similar object for 30 seconds and then unplug the power cord and plug it back in.
Apr 09, 2009 | Linksys Wireless-G Broadband Router
Have a Linksys Wireless-G 2.4 GHz broadband router
If you don't know the wireless code, you can simply reset the router. There's a reset button at the back of the router. Press and hold it down for about 15 seconds, then unplug the power for 10 seconds and plug it back in. That will clear the wireless code.
Nov 21, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
