Question about GE Dryers
I have a GE gas dryer and it runs but has recently started making a thumping noise. I can spin the drum by hand and it doesn't make the sound. What's wrong with my dryer?
  • GE Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Apr 11, 2011
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Thumping noise when my ge dryer runs? Any idea what needs to be replaced? It's only two years old.
Hi thefaunces...
Sounds like the drum rollers have flat spots on them, they will make the noise you describe.
Please take time tor rate me
Aug 21, 2011 | General Electric DCVH640GJ Gas Dryer
I have a ge frontload washer and it recently started making a really loud noise when in spin mode. It sometimes bangs the side also. What's going on?
It could be a few things that could be wrong with it. With the washer empty does the wash drum sit centered within the door? Also the drum should be level and not sag down or up. If it does, then it could mean the the springs or shocks are broken. You can check shocks by removing the two screws on the front bottom access panel. There are two shocks, and are mounted on the bottom of the the drum.
If the drum sits level and centered in the door, turn the drum by hand and feel how it spins. It should spin true and quietly without any kind of thumping or scaping noise. If it makes a thumping or scraping noise, or it wobbles as it spins this could mean the the spider arms that support the wash drum are broken. If it does not make any abrupt noise when you spin it by hand but when the machine is in a spin cycle, it spins with a loud roar like a jet plane is landing in your laundry room, then the bearings are gone.
It can be very expensive to have these machines servied since the machines needs to be taken apart to get the drum/bearing assembly. If you are handy, you can replace the bearing and seal for less than $100 in parts, but, if the spider assembly is broken, the parts alone can cost as much as a new washer.
Apr 19, 2011 | GE WSXH208A Front Load Washer
I HAVE A GE GAS DRYER MODEL DDG5980VALWH SER. 3F302890G. WHEN THE DRUM TURNS IT MAKE A THUMPING SOUND,,NOT REAL LOUD. MORE OF A THUMP THEN A SQUEAK.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | GE Dryers
I have an electric frontload dryer. If I turn it on with nothing in it, it sounds like there is a shoe tumbling around. If I open the door and spin the drum by hand, each revolution the drum makes, there...
heatman101
Asker
Nov 22, 2010 | GE Dryers
Dryer heat comes on with start switch hold on, but will not run the drum.
so you hear the motor spinning (the hum of a motor), then most likely the belt has broker or the tensioner pully has broken/fallen off..
Was it making any funny noises before it failed. Thumps, squels, grinding...?
Usually driers have very little bottom and you can see the motor, tensioner and belt by turning it on its side. or pull of the bottom. Be sure to unplug it and if it is gas, turn off the gas. if gas be really careful with the hose... IF YOU ARE A LITTLE UNSURE and it is gas, just call a repair person. Electricity burns and sparks, gas explodes!
Peace,
Mar 03, 2010 | GE Profile DPSR473EW Dryer
Dryer won't spin. sounds like belt off tract
Hello there
here is some troubleshooting tips for you ok
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Oct 26, 2009 | Whirlpool GGQ8831L Gas Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
G.E. Gas dryer starting making thump noise when drying,
The drive belt has lost some of its rubber ribs, you need to replace the belt
Aug 15, 2009 | GE DBXR463EDWW Electric Dryer
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
