Question about Denon AVR-1709 Receiver
I have a Denon AVR-391.Now it is starting to stop functioning. The set will work then after a while I can not operate any of the commands via remote or manually. The set will not turn off nor am I able to Reset the Micro. The only thing I can do is to unplug it and plug it back in. Then when I turn on the set it creates a quick pop (in the speakers) before continuing normal operations.
  • 84 Answers
If you have had this unit for a while I would try vacuuming or blowing it out because it sounds like the issue you are having is due to heat building up in the unit. Also make sure you have adequate airflow around the unit in other words make sure you have at least 2-3 inches of clearance on all sides and nothing sitting on top of the unit.
Posted on Apr 11, 2011
  • ssrs676500 Apr 19, 2011
    I have the same issue! I found out that if I leave the unit on continuously this problem does not occur. If i turn it off and turn it back on to use it, then it does not accept any input of commands remotely or manually. Has something to do with a "hand shake" between devices.
  • unvoiced Aug 16, 2011
    Its not a heat issue but rather a firmware problem. After talking to two denon reps they said its a known problem and will need to be serviced. All thats required is for the shop to update the firmware.
I have a Denon avr 391 and it worked fine for 4 years. Now I cannot get any sound out of it. Any idea what's going on. Help
could be a bad headphone jack. There was a commong problem with denon receivers around that time where the headphone jack had contacts that would short and make the unit act like there were headphone plugged in even when there wasn't. Sometimes you can clear the error by inserting a headphone plug and unplugging it a couple times. If it continues to happen, then you can get the headphone jack replaced.
Jan 04, 2015 | Denon Avr-391 Av Home Theater Receiver
Srp4004 and denon avr-391
Do a code search method. If there is a code, you can set it. If you wish to get more details, check this site. Pull up older posts there. http://electronicshelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check this site too. http://electrohelponline.blogspot.com/
Apr 28, 2013 | Philips SRP4004 Remote Control
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
I have a Denon AVR - 391 receiver and was wondering the best way to connect my CD player to as there is no provision for CD player
Sure it does:
http://www.retrevo.com/support/Denon-AVR-391-Receivers-manual/id/23705bh449/t/2/
Analog RCA cables go to anything available: DVD; SAT/CBL; DOCK
and/or
Digital audio goes to whatever is available: COAXIAL (SAT/CBL) or OPTICAL(TV)
Jan 09, 2011 | Denon AVR-787
My AVR 391 goes on Standby and freezes there.
Seems you cannot fix this issue yourself. If the unit is still under warranty, Denon will replace a chip which has a flawed firmware. The unit cannot be updated remotely and a physical repair is necessary.
Sep 18, 2010 | Denon AVR-3200 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
Video off for Denon AVR-3805
please see if this tricky approach will work
1) go and download the file v.vtr
http://www.sendspace.com/file/tb9yf3
2) borrow a pocket pc with infrad red port
3) download the program vito remote and install that
4) use the file v.vtr and set up the device
5) the F1 command should be same as the "video off" button
Aug 16, 2008 | Denon AVR-3805 Receiver
Remote Control for Denon AVR-5800
I have 2 Denon Universal Remote RC-8000 AVR for sale if you like you can send email Shavoniemail@yahoo.com
Thanks, Scott
Oct 24, 2007 | Denon RC-8000 LCD Touchscreen Remote...
Denon AVR-1707 Receiver - remote stopped working
please apply a new fresh battery to it-confirm from right orientation(polarity)-try to apply a contact cleaner spray over the bad button and press it many times.-remove any thing between remote and receiver.-you can use universal remote and confirm befor you buy the new remote that it support your receiver.
Sep 21, 2007 | Denon AVR-1706 Receiver
Denon AVR-1709 Receiver Logo
572 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
