Question about Kitchen Ranges
What is error code e-8 on wascomat commercial dryer
3 Suggested Answers
  • 117 Answers
SOURCE: I dont have a service manual for my commercial
Call wascomat at 1-516-371-4400 head quarters I used to work there
Posted on Jul 12, 2011
  • 74 Answers
SOURCE: wascomat dryer error codes
Check the following link: http://www.laundrynation.com/manuals/wp-content/uploads/2011/05/wascomat_dryer_selecta_control_programming_manual.pdf
On page 13 it identifies the E 08 error as overheating air (inlet or outlet). Chances are, it is the outlet that has gotten gunked up from lint or other material. Pull the vent tube off, vacuum out lint traps, clean the outlet tube, reset the machine. If the dryer is linked with other dryers on a multiple-link vent system, cleaning the vent lines may be necessary to avoid the problem.
Posted on Feb 06, 2014
Wasco td 75, error code E-15
Although I cannot find anything that explains what error code E-15 means for the TD75, I did find an exchange with a technician that explains what the error code means for a TD30/30. If it is similar, the exchange also describes the areas of machine to check for issues.
Wascomat Dryer td 3030 15 Error Trouble Shootings
Jun 30, 2017 | Office Equipment & Supplies
Tip
Where to find Wascomat Laundry Parts
Laundry Parts Market is a growing online resource for commercial and residential laundry parts. We have a large selection and stock of hard-to-get Wascomat Parts. Shop here http://www.laundrypartsmarket.com/Wascomat_Laundry_Parts_s/1830.htm or email parts@laundrypartsmarket.com if you need a part #.
on Aug 22, 2013 | Wascomat 471 812637
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
My Wascomat TD77 dryer keeps shutting down after 5 minutes and shows E 14. What is wrong with it.
Taken from the following: https://www.wascomat.net/pdfs/487032981.pdf
This is for a different model, but the codes are likely the same.
It is related to non-ignition of gas. You may need to switch on your gas supply, or service your ignition coil.
Resetting gas error
When the ignition control fails to detect a flame a error code E14 is displayed. When this condition occurs, the gas valve is shut off and the ignition control must be reset manually.
Resetting
Open the operating panel and press the gas reset button on the back of the user module board for one second.
See the picture of the gas reset button section 21
NOTE! When resetting the system the dryer must operate on a program with heat and when the heat indicator is on.
Error code
Error code 14 is a normal occurrence when first starting up a dryer, since air in the gas line must be purged.
Aug 26, 2014 | Dryers
Wascomat w655s what is error code E13 ?
www.teetersproducts.com/.../Used%20Equipment/.../Wascomat%20-%20...
Jul 13, 2014 | Wascomat Parts Wascomat 973957 Washer...
Wascomat dryer error codes
Feb 06, 2014 | Dryers
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Kitchen Ranges Logo
186 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
