I have a Av receiver tx-sr506,and it has these proble,the standby led is flashing and when turn on it goes back to the flashing standby mode,can i have any idea to fix it or any tech who can fix it.
  • 635 Answers
The flashing indication is telling you to seek professional help. You have have a short circuit in your output stage and your Onkyo is going into protection mode to prevent further damage. The least you can do is to switch off speaker A and B and try switching on the Receiver. If the then the system turns on you have an external shorting in the speaker wire or speaker itself.
Posted on Apr 11, 2011
Im Need Help Resetting My ONKYO TX-SR6O3X RECIEVER Its By Itself Or The Owners Manual to Help me reset it
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
Onkyo TX NR515 .. when in standby mode .. light is not coming on .. everything works fine .. i must have pressed something by mistake but cant work it out what ... on the display panel in standby mode...
If Zones are turned on or, if a mobile device connected to the Front Input is charging (MHL), the HYBRID STANDBY indicator won't light. See the TX NR515 owner's manual at http://filedepot.onkyousa.com/Files/own_manuals/TX-NR515_English.pdf for more info.
Feb 19, 2015 | Onkyo TX-NR515 AV Receiver
How to reset factory settings for onkyo tx-sv303pro without the remote
To reset the AV receiver to factory default ,turn it on and, while holding down the (VIDEO 1/VCR) button, press the (STANDBY/ON) button "Clear" will appear on the display and the AV receiver will enter Standby mode. :)
Jan 14, 2014 | Onkyo Audio Players & Recorders
I have an Onkyo TX-SR506 that does nothing but blink a red light when plugged in. This happened after a power-surge from a lighting storm hit it. Is there any trick or magic key command to get it out of...
Page 90 of the manual describes the procedure for resetting it.
"If you can't resolve the issue yourself, try resetting the AV receiver before contacting your Onkyo dealer.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Note that resetting the AV receiver will delete your radio presets and custom settings."
But that may not help.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 31, 2011 | Audio Players & Recorders
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
I need to know if it is possibly to plug an iPod into my ONKYO AV RECEIVER TX-SR506?
Yes it is. The easiest way to go about this is to get a stereo mini male to left and right male rca cable. Connect the stereo mini end into your ipod, and the left and right male RCA end into an available input on your reciever. Change the input on the reciever to correspond with the input you connected to. Ensure your ipod is powered on and playing with the volume turned up. This set up will play through your reciever but will not charge your ipod. If you want it to charge while playing, than you will need to get a dock.
Jan 05, 2011 | Onkyo TX-SR506 Receiver
I have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Nov 04, 2009 | Onkyo TX-SR506 Receiver
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
215 people viewed this question
 Grubhead
Grubhead
