Question about Sony PlayStation 2 Slimline Console
My disc brake post isnt broken off, or loose at all, but still sometimes has trouble disengaging the disc brake. Any idea if this could be caused by a sticky or jammed lever? should i try putting a little elctronic cleaner alcohol down in the recieveing are for the post that releases the brake?
    Sergeant:
    Champion:
  • 207 Answers
Your tray is unalined needs fixing but sometimes alittle electrical great works on the gears plus the belt might be bad you can buy a new one on ebay for a dollar..
Posted on Apr 11, 2011
Rolls royce 1986 cannot disengage brake?
crack open the bleeder valve one by one for each wheel. to release pressure on wheel cylinders. Im sure they are sticking. Might want to look into replacing the lines and fluid. Before doing anything double check to confirm the emergancy brake isnt engaged
Dec 16, 2012 | Ammco Combination Disc/Drum Brake Lathe
1994 LINCOLN CONTINENTAL
Hi Terry,
Please check out this Link : http://www.autopartswarehouse.com/featured/books_and_manuals/1461465620.html
Here you will find the details regarding your Car and how you can check and repair the breaks without taking it to a mechanic.
I hope this helps.....
Jun 02, 2008 | 1994 Lincoln Continental
In recent times my 2000 Rav4 2000 is having problems with clutch - in 1st & 2nd mainly you put foot down on accelerator and get no go??? also at same time the brake seems to be juddering when...
Hi Steve,
The clutch and brake problems are separate. The clutch problem would seem to be a worn clutch plate and or pressure plate. These will need replacement which means the removal of the gearbox.
The brake shudder could be caused by broken or loose brake parts, but is more likely to be caused by worn brake discs, which will require either skimming or replacement.
Regards Johngee10
Mar 08, 2011 | 1998 Toyota RAV4
Broken brake line on 1990 chevy 4x4 pickup (K1500) broke and drained master cylinder. Front disc brakes/rear drum brakes. ABS system. Once brake line fixed what is the bleeding procedure that must be...
1990 Chevy 4.3 l engine runs rough at idle half the time-- sometimes it's OK, other days it's rough and can smell raw gas, as tho it's running rich... any ideas?
Nov 27, 2010 | 1990 Chevrolet K1500
When i hit the brakes every so often the car
Your going to have to take it to a transmission shop and have them scan the car for a DTC code. It sounds like the transmission's torque converter is not disengaging causing your engine to surge forward every time yu try to stop. It could be as simple as a bad or broken throttle body position sensor that is causing your problem. Good luck and keep me posted.
Nov 03, 2009 | 1997 Lincoln Continental
Wont shift outta park.
Make sure that your brake lamps are working. I have seen the brake switch go bad and cause it not to come out of park. Good luck.
Jul 30, 2009 | 1997 Ford Taurus
Slamming noise from rear of jeep
Without checking it out it would be hard to pin down, but it pretty much HAS to be one of these things. A broken shock or spring, a broken brake disc or one of the discs in loose in the caliper. If it is a shock making that kind of noise it would likely be visibly broken and show other signs (bouncing, popping).If it were a spring~ sometimes they are just noisy, but they should also make the noise at other times.If you haven't had the noise occur at any other time (rough terrain, tight cornering) it's almost certainly brakes.It's a good idea to replace all four at a time~ in my experience if two are worn, all are worn.
Apr 22, 2009 | 2000 Jeep Cherokee
Ongoing Playstation2 Slimline issue
Hi...
The laser wont go on unless the disc is IN and the cover is closed.
There is a disc brake post coming down from the LID . If it's broken , the disc wont spin/read.
The post is on the back right of the LID it (normally) goes thru a cutout that moves the brake out of the way.
Other troubles are debris on the worm gear that drives the laser assembly back n forth.
If the post is broken drill out the old one and put some kind of plastic or wooden stick about 1/4 inch long in it's place
Jan 20, 2009 | Sony PlayStation 2 Slimline Console
Broken e brake cable
you need to get under the dash or kick panel on the left hand side,,,take a flat blade screw driver with you and a pair of plyers,,,you should be able to trip the release with just those tools.
Jan 17, 2009 | 1999 Chevrolet Silverado 1500
PS2 slim Power Problem - Light is red goes green but nothing else.
Hi Leostg,
I have seen this a couple of times.  Lightning or an overload has burned up the motherboard. Its not a fuse, its a fried Emotion Engine processor.   Best advice on dead motherboard is to probably total it unless you can get a low price motherboard replacement. My cost on a new motherboard for slim is about $55.  If you want it fixed, replace the motherboard.  Really you may be able to get another Slim for $55 or less. If you look on ebay  for another motherboard do not take any chances on used motherboards. Go for a broken slim model that will boot up but want read discs. When you get one that boots up, use its motherboard in your Slim.  This will be your best deal at getting your slim up and running once more.
Please give me a Solved vote. I believe you only get one vote and its locked.   I have put a lot into your solution and hope you will show appreciation by voting solved.
Oct 16, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
216 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
