Question about HP DeskJet 340 InkJet Printer
How do I remove cued documents without printing them
  • HP Master
  • 32,281 Answers
Click Start - printers and Faxes - double click on your printer then you will see a list of documents that are queued to print.
Click on the print document you want to remove then click on Document at the top and then click Cancel.
Repeat for other print documents you want to cancel.
Posted on Apr 11, 2011
Document size and page size when printing
Its not a setting for page size, that must always be set to the paper size. The best way is to remove the margins in the document by editing it in a PDF editor. Alternatives are a bit of a bodge. When you print try changing the size to 115% of original.
Dec 19, 2013 | HP - HP Photosmart 8250 printer
CANON IP 4300 PRINTERS WILL ONLY PRINT ALTERNATE LINES
I think your text document didn't fit the page. I have done that before. It overruns and the extra becomes the lines inbetween. To fix this use microsoft publisher to print it so that you can choose the paper size and the borders and fit the document within the space allowed.
Nov 24, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
Erratic print with canon ip 4300 printer
The document should be formatted as a table with text inserted rather that a group of text boxes.
Nov 24, 2013 | Canon Office Equipment & Supplies
When removing the document that prints, how do I remove it from the continous paper without wasting a sheet every time?
Press the view button tear off the paper then press view button again and the printer will bring the paper back down, I think anyway
Mar 23, 2012 | IBM 6400 Matrix Printer
My printer starts to print a picture or document and prints a few lines and then sits there and then comes through without printing the rest of the document or picture.
Hi, take out toner cart, and shake gently, and then look back in
you will likely find a pile of loose toner needing removed.
Clean VERY carefully, either with a vcacuum and LONG nozzle or slightly moistened tissue
OR
uninstall it then install it
May 14, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Paper feeds, but won't print. As far as I can tell there is ink.
Ensure the Paper Tray is Not Overfilled Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray Adjust the Printer Paper Guides Adjust the paper guides to fit the size paper being used (Figure 1). The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides. Locate and Remove Any Obstructions Inside the Printer and Input Tray Open the front cover and make sure the kickstand (if there is one) is engaged. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects. Close the cover. Remove all paper from the input tray. Inspect the input tray for any obstructions. Remove any visible obstructions. Reinsert the paper. Determine if Multiple Sheets Are Fed at Once From the Paper Tray or ADF Determine if multiple sheets are fed at once from the the paper tray or Automatic Document Feeder (ADF). Verify the print media installed is compatible with the printer Clean the ADF Paper Feed Roller Disconnect the AC power from the printer. Open the cover of the Automatic Document Feeder (Figure 1). Figure 1: Raise the Cover of the Automatic Document Feeder Using a damp paper towel, gently wipe the rubber roller to remove any ink or paper debris (Figure 2). Figure 2: Paper Feed Roller on the Automatic Document Feeder Close the cover and reconnect the power. Reseat the Dell Printer Power Adapter If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a Dell? inkjet printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends. If the printer queue icon is showing in your system tray (by your clock), you may have documents that are paused for printing. To resume printing a paused document: Double-click the printer queue icon to check document status of the active printer. Right-click on any documents that show Paused under Status, and then click Resume in the drop-down menu. Try a Different Type of Print Media Many image quality and paper feed issues are caused by the type of print media being used. Try a different type of print media that is specifically made for this printer. Replace the printer.
Nov 22, 2009 | Dell 968 All-In-One Printer
Printer won't print word perfect doucments
try a different pint driver such as a pcl4or5e.
Apr 15, 2017 | Office Equipment & Supplies
Canon PIXA MP160
try if ur catridge is fixed in slot perfectly or not otherwise remove it and fix this again. perhaps it solves ur problem...............
May 16, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP DeskJet 340 InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
