My GAF 2680 slide projector has a burned out DAT lamp. How do I remove it? I have tried pulling it straight up and also by twisting it but I can't seem to budge it either way. The unit has sat in a closet for a number of years and was running perfect until the light went out and I believe that it is the original bulb. The user manual must have been misplaced during one of our moves. I hope that you can help. V. Caruso
  • 105 Answers
SOURCE: Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to
Posted on Oct 30, 2007
SOURCE: Sony KDF-E55A20 Lamp Shut Down with no blinking lights
If you TV is about 2 1/2 yr you probably need a new lamp they only last about 3 yrs. Mine popped one night and now picture comes in for about 1 min and goes out, I ordered a new lamp today they run $199. There is also a know issue with the thermal fuse. The part cost about $3 and if you know a lil about electronic you can replace it yourself
Posted on Nov 17, 2007
  • 51 Answers
SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Posted on Dec 08, 2008
  • 11 Answers
SOURCE: Half inch black line down middle of sent & copies -is NOT SCANNER
the scanner will give you problems only when you send not receiving or incomings, it sounds like your corona wire and the grid needs to be clean this is part of the drum unit with a cute tip (you will need more than one) pull out the image unit and toner it's two pieces in one. you can clean the corona wire (corona wire is the thin wire that charge the drum unit with a positive charge located at the center of the drum unit and is thinner than a human hair and under that you will see the grid make sure all that section is cleaned. if you have compress air will help)
in my opinion you whent to far trying to check some other things that are not necesary.
hope this will help
any other questions please let me know.
Posted on Mar 25, 2009
SOURCE: infocus IN24 lamp not lighting up
Posted on May 06, 2009
How do i remove the bulb from a gaf 2100r slide projector
The bulb pulls out. You don't want to twist it, because it is seated with one big pin in the middle and four smaller ones around it. The big pin in the middle has a fin on it, to make sure you get the others in their right places.
To get the old one out, you want to remove the metal housing for the lens that surrounds the bulbs. Pinch the sides that are next to the open end of the housing a little bit and jiggle it. It'll come out fairly easy. Once that is out of the way, you can get a good grip on the bulb and pull it straight out.
As for new bulbs, you can find them on the Internet. The best price I last saw was for $27.
Dec 30, 2012 | Office Equipment & Supplies
How do I change my projector lamp?
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp '
Apr 11, 2012 | Office Equipment & Supplies
I have a sears easi-load circular tray 9985 for a slide projector. I don't know what brand projector it will fit in. Thanks.
I have a number of these. The printing on the box is as follows:
For use with Sears 9833, 9843, 9853, 9854, 9883, 9884, 98833, Sawyers, GAF and Anscomatic tray-loading projectors.
Apr 30, 2011 | Cameras
How do I open my Gaf Hush-a-matic Slide Projector 2100E? I want to put in a reel of slides and can't figure out how to do it.
Push in the little red buttons on either side and pull forward. It might take a little doing but it'll come open.
Mar 04, 2011 | Cameras
How do I replace a burned out backup light on a 1998 cheverolet silverado c-1500 pickup truck?
Removal & Installation Cab/Chassis gm-06-00-1071.gif
To Remove:
  1. Disconnect lamp assembly electrical connector.
  2. Remove nuts and lamp assembly from bracket.
  3. Remove lens screws.
  4. Remove lens, gasket and bulb.
To Install:
  1. Install lamp assembly and nuts to bracket.
  2. Connect electrical connector.
  3. Install bulb, gasket and lens.
  4. Install lens screws.
Except Cab/Chassis gm-06-00-1075.gif
To Remove:
  1. Lower endgate.
  2. Remove 2 tail/turn signal lamp assembly retaining screws.
  3. Rotate tail/turn signal lamp assembly and remove from vehicle.
  4. Disconnect lamp assembly electrical connector.
  5. Remove bulbs by pulling straight out of bases.
To Install:
  1. Install bulbs by pushing straight into bases.
  3. Install tail/turn signal lamp assembly to vehicle and secure with 2 screws.
Jul 17, 2010 | 1998 Chevrolet C1500
The lamp on The Infocus X1 projector at my work is burned out and i need to replace it, but do not want to attempt to without knowing how first can some one give me a guide on how to do this?
very simple. remove the lamp door on the left side (looking from the front) using a flat head screwdriver. unplug the plug, and unscrew the 2 screws. pull the lamp out. put the new one in and reverse the instructions. piece of cake!
Apr 02, 2009 | InFocus X1 Multimedia Projector
196 people viewed this question
