Question about GE Built-In Room Air Heat Cool Air Conditioner
I bought an air conditioner and the plug does not match my plug It says it is 230/208 Voltage what can i do
  • GE Master
  • 8,404 Answers
What is your house voltage?
This machine should run on a dedicated circuit. Have one installed.
Alternatively, you could return the AC for a 110 VAC model.
Posted on Apr 11, 2011
What is a capacitor
it is what starts yout compressor and fan motor,,,, it causes the current to lead the voltage thereby turning the motors
Jul 01, 2014 | Ruud Matching Split Air Conditioner
Why does the plug does not fit the outlet for a GE air conditioner AEL14*?
Voltage is not 110v May be 220v thus the plug won't fit into a wall socket.
Jun 16, 2014 | GE AJCQ08ACB Air Conditioner
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
59516.331 need run and start compacitor mdf.
Remove the ones that you have and match the voltage and micro farad rating printed on them.
Aug 27, 2013 | Dometic Rooftop RV Air Conditioner
Anyone know where I can get a fan motor for the indoor unit of my centrex CTAR65GW split system air conditioner. i think the motor may be generic for most of the cheaper split air conditioners. Denis
I buy alot of those motors through www.grainger.com
match up the hp, rpm, shaft size, mounting, voltage, etc... this can take a bit, but you will find a motor for partically anything there...
heatman101
Aug 11, 2010 | Heating & Cooling
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
The plug wont reset
Hi, sometimes they burnt out, or maybe there's a short circuit in system, you can remove it and replace with regular plug to match, from hardware or electrical store, it's just like a circuit breaker in a plug, just additional protection, but your house panel have it's own circuit breakers, it's safe to remove and put regular plug to match receptacle.good luck.
Aug 03, 2009 | Mastercool 67680 Evaporative Cooler Air...
My son's landlord brought out a new Frigidaire 12,000 B.T.U. room air conditioner.He,(my son) plugged it in and the unit made a popping sound with a flash of light, followed by the smell of burnt plastic!...
hi,
possibly sounds like a household wiring issue, if the unit was brand new and somehow got your 120 volt air conditioner hooked up to 220, that would cause that. You may have to ask some questions about who wired that plug that the air conditioner plugs into. It could be the other way around as well is the air conditioner 220 volts and the plug 120? Have someone check the voltage coming out of the plug. the voltage for the air condtioner and the wall MUST match. If its 220, that was your problem and your air condioner will need extensive service/replace. If it isnt, and the air conditioner was subjected to the lower voltage , it could have caused that as well and the circuit board fried, but hopefully the major components are okay check to see if your wall voltage and your air conditioner voltages are the same, they have to be, your unit will need service either way but hopefully the latter which is cheaper, and call a licensed electrician to check out that plug.
J
Aug 06, 2008 | Frigidaire Heating & Cooling
GE Built-In Room Air Heat Cool Air Conditioner Logo
53 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
