Question about Samsung Computers & Internet
My monitor screen went out and now I can't turn it back on
    Problem Solver:
  • 8 Answers
Unplug your monitor from the power for about 5 minutes. After 5 minutes press the power button, and then plug it in, turn it on.
If it still does not turn on, the monitor is dead and you'll need to replace it.
Posted on Apr 11, 2011
  • Kimberly Spurling Creed
    Do I need to hold power button as I plug it in it will not even turn on?
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
I've had my monitor for years with no problems. Today, when I turned on my computer, the monitor flickered. Then the screen went black, and the power button began blinking (green). When I turned it off...
A couple of things to check. First make sure that all the connections are in place. That is, the one at the PC and the one on the back of the monitor. Second - Make sure that the video card is seated correctly in the PC. Third - Replace the monitor cable. Fourth - Check with another monitor, if possible.
Mar 27, 2010 | Dell E153FP 15" LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
I plugged it in and the screen came up for a second and then went black. I turned it off and turned it back on, the screen came up for a second then went black again. What could be wrong?
is the cpu running ,, with connection to monitor,, you can try restart,, and go to display properties,, screensaver,, there power button and change the settings,,,
Sep 27, 2009 | Dell E173FP 17" LCD Monitor
The screen on my Gateway monitor suddenly went light blue. Has anyone else had this problem or know the solution to get it back to white?
Does the screen remain the same color when you turn it off and back on, unplug it and back in, or disconnect it from the pc and reconnect it?
Jun 15, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Jan 19, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Monitor turning black
the backlight fluorescent bulb is burned out.
Dec 26, 2008 | Computers & Internet
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
219 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
