Question about PK Dsc Pk5508 Pk 5508 Powerseries 8 Zone Keypad
How do you change the Master Access Code on the PK5508 keypad for the DSC Power Series Control Panel PC1616?
How to program Clicker Keypad with Master Mechanic 501MM
Master mechanic 601mm on the buildmark - YouTube
? 2:14
www.youtube.com/watch?v=ga8yaYi0brY
Feb 18, 2012 - Uploaded by RGDMan
Master mechanic 601mm on the buildmark .... Reset Garage Door Keypad Code PIN & Remote Control Opener - Duration: 2:51. by ... Chamberlain CLICKER Universal Remote ControlProgramming Video - Duration: 5:21. by ...
Sep 28, 2015 | Building Materials
How do I reset code on dsc
*5
Master code
Enter 40 for new master code
Enter new code twice
Keypad will beep three times rapidly confirming successful entry
Press # a couple times to exit programming.
Aug 26, 2014 | DSC Alexor Alarm System Wireless Panic...
HOW TO CHANGE MASTER CODE DSC PC2550RK
You need the installers code (default is 2550). To change master code, enter the following:
[*] - [8] - [Installer Code] - [2] - [5] - [New Master Code] - [#]
Jun 24, 2014 | DSC Pc2550rk Pc Classic Pc2550 Rk Keypad...
Change language on DSC maxsys keypad
I can help you default the system. I got this out of the manual.
Hardware Reset of Memory to Factory
Defaults
If the Installer's Code is lost through inadvertent
programming, the only means of reprogramming the
system is by a hardware reset. If the Installer's Lockout is
enabled, there is no way to reprogram the system without
entering the correct Installer's Code.
The PC4010 can also be reset through software in the
installer's programming. See "Factory Default" in the
Programming Guide.
Note: Panels returned to DSC with the Installer's
Lockout feature enabled and no other apparent
problems will be subject to an additional service
charge.
To reset the panel to factory default conditions:
1.Power the system down by removing both AC and
battery power to the main panel.
2.Short the zone 1 terminal and the PGM terminal on the
main panel.
3.Restore power to the main panel.
4.Wait for 20 seconds then remove the short between
the PGM and zone 1.
5.The system will have reloaded the memory with
factory defaults. All modules will have to be enrolled
again. The event buffer is the only part of memory that
is retained during a factory default.
May 21, 2014 | Home Security
How to reset sensor for keypad pk5508
I am truism to reset the emergency code that was pushed in error. This code is yellow in color and a exclamation point in the middle.
Apr 11, 2012 | PK Dsc Pk5508 Pk 5508 Powerseries 8 Zone...
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Need to change alarm code on ademco alarm ststem
We need more information. The answer is different for different models and Ademco has dozens of models. Tell us the model of your control panel, usually on the inside of the panel cabinet door) and we can help you.
Oct 04, 2010 | Ademco 1 Wave 2 Alarm Indoor Siren Vista...
Error code F1 flashes and beeps on control panel
Hi
Error code F1 means a faulty keypad or connection problem with the keypad. You will need to check the connections of the keypad with the main board. Pressing Start/Cancel key may temporariliy resolve the issue, however, to resolve the issue you might need to change the keypad if the wiring to the keypad seems ok.
1. Disconnect power to oven.
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
If it still shows as F1 then you'll need to replace the keypad.
Hope it helps...
Daniel
Aug 13, 2010 | Magic Chef Ovens
Need operating manual
http://www.paradox.com/Documentation/Manuals/ARCHIVES_UserQuick/SPEKEU-03.PDF
See if that helps. Let me know if you need a new panel/keypad. I have DSC 1616 Power series.
Stewart
May 30, 2010 | GE Security Simon 3 Wireless Home Security...
PK Dsc Pk5508 Pk 5508 Powerseries 8 Zone Keypad Logo
510 people viewed this question
Top PK Home Security Experts
Lawrence Oravetz
Are you a PK Home Security Expert? Answer questions, earn points and help others
