Question about Mitsubishi LT-40134 40 in. HD-Ready LCD Television
We have a brown line on the right side of the screen from top to bottom that never goes away - its about 4 inch from the right side of the screen what is the cause and what is the fix
  • Mitsubishi Master
  • 8,457 Answers
This problems most likely causes by the board that call the T-CON decodering board.This board sit at the bottom at the middle of the LCD screen panel decodering the codes before sent it to the LCD screen panel for a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Posted on Apr 11, 2011
2 Suggested Answers
  • 713 Answers
SOURCE: I have a vision 42
your flat panel pixels in tube is going bad.
Posted on Feb 16, 2011
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
My lg problem
The left and right Xrlt pannels are probably bad.
Feb 25, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Yahoo Messenger
1- click on top of the window on the title bar, while holding your left mouse button...move the window to the left until you see the right bottom corner about 1 inch from the right corner.
2 - click on the right bottom corner to resize the window and drag it all the way to the left about an inch away from the edge.
3-repeat step 1 until the window is back to normal size
Feb 24, 2008 | Computers & Internet
Mitsubishi LT-40134 40 in. HD-Ready LCD Television Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
