Question about Canon Office Equipment & Supplies
The canon cp1200D calculator has the overflow "E" button show and it locks the calculator when in print mode. It also does not print the proper numbers. this calculator is 2 days old and the second one they sent as the first one did the same thing.
4 Suggested Answers
  • 5 Answers
SOURCE: canon p23-hd v
download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Posted on Jan 10, 2009
  • 7993 Answers
SOURCE: the calculators screen is not fulling showing the
Hello
If it is too dark
Try reducing the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
If it is too light increase contrast
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Posted on Sep 08, 2009
  • 102366 Answers
SOURCE: My student has a ti30xIIs calculator, but she
Press 2nd [SCI/ENG] and select "FLO" for floating decimal.
Posted on Sep 08, 2011
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
E appear on screen, number keys not working.what should I do.
Customer Reviews: Canon MP11DX Printing Calculator
www.amazon.com/Canon...Calculator/.../B0006HWF...
Amazon.com, Inc.The keys (i.e., numbers) get stuck almost every time I use it. I have to actually wiggle the numbers so I can enter the next number. It's not the tape on the ribbon; ...
3 Using your calculator for fractions - The Open University
www.open.edu/...calculator/content-section...
United States Open UniversityMay 3, 2012 - Early Years ยท Working with Young People .... 11 Natural logarithms and powers of e on your calculator ... The figure shows the display on a calculator screen.... If your calculator is not in Math mode, repeat the steps of Activity 1. ... arrow keysto move between the boxes when inputting the mixed number.
[PDF]Canon MP270 series / MP250 series On-screen Manual
Dec 15, 2015 | Canon P27-DH 12 Digit Mini Desktop...
On screen show E and can not print or .How to remove
Your calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Stuck in overflow mode
I could not find the Manual for your Model P-126 D, but I found the one for the P-160DH (USA). I copied the part on the Overflow function. Here it is. I may work for your model.
Dec 20, 2013 | Canon Office Equipment & Supplies
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
Hoe to I get my hp 12c calculator to show the begin/end format? It did, now when o hit "g" "7" beg or "g" "*' end, can not get to display? Thank you !
Begin mode is obtained by pressing [g][7] and it should then show BEGIN in the bottom line of the display. End mode is obtained by pressing [g][8]. End mode does not not show an indicator in the display because it is the default mode, so if BEGIN isn't showing, then the calulator is in End mode.
Mar 18, 2011 | HP 12c Calculator
Canon P170-DH
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Jan 10, 2009 | Canon P170-DH Calculator
Overflow won't clear
Look for the reset button, then remove the batteries - this should fix it.
Oct 22, 2005 | Canon P23-DHV Calculator
219 people viewed this question
old marine
old marine
