Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 21 hp single cylinder ohv briggs. Oil came through the breather tube creating a lot of smoke. It also blew the head gasket. After I repair the gasket can I let the breather vent naturally and plug the inlet on the air intake?
    Scholar:
  • 54 Answers
It sounds like the oil was filled way too much and was kicked around violently as you started it, usually the oil filler plug will show full with only an inch or less showwing on the dip stick which is part of the plug. You have to screw it in and take it out to get the right measurement. Also cold weather may be making your oil very thick if it is a multi weight 20-50W oil for trucks, it is super thick when starting up. I would try a light oil like 10-30 if allowed in your manual, keeping in mind this motor always travells 3500 rpm where a truck or car would only be doing 700 rpm when cold started. For very cold startup conditions I would use Syntec 5-30W 100% synthetic oil (it's about five times more expensive than most) which I use in a 2002 VW diesel Jetta turbo with great results so far and it still gets 65 mpg after 10 years driving!
Posted on Apr 11, 2011
What should the compressin be on a briggs
What is the compression ratio for my engine?
Briggs & Stratton side valve (L-Head) engines use a compression ratio of 6 to 1.Our Overhead Valve (OHV) engines use a compression ratio of 8.5 to 1.
What would cause my engine to "puff" smoke while it runs?
White/blue smoking usually indicates the burning of oil. Causes to this condition include:
  • Overfilling the crankcase with oil
  • Incorrect oil grade
  • Operating engine at greater than a 15 degree angle
  • Inoperative crankcase breather
  • Crankcase air leak
  • Blown head gasket
  • Worn cylinder and/or rings
  • Turning/Tilting the engine on its side for any reason (storage, changing oil, etc). If the engine has to be tilted, ensure the spark plug is facing upwards to help prevent oil from escaping the crankcase.
Also, be aware that any small air leak can cause an excess of air entering the crankcase and will create a higher oil mist than the breather is capable of handling. The excess oil will then return through the breather tube and back to the air filter. Engine oil capacity is dependant on your specific engine model. To determine your engine's oil capacity, please visit our Oil Capacitypage. Oil level checking and changing intervals are available on ourMaintenance Schedule page, as well as a hyperlink (text highlighted in blue) leading to oil changing procedures.
The "Oil" section of your Operator's Manual also contains this information. Other possible causes include operating or tilting the unit at an angle, an obstruction in the breather tube (located behind the air filter), damage to the cylinder/piston rings, etc.
Jul 23, 2015 | Garden
WHY DOES WHITE SMOKE COMES OUT OF THE SIDE
If it's coming from around carburetor area than you most likely have a blown head gasket. It's building up to much pressure in block and its blowing out your vent tube.
Jul 28, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Briggsload Stratton 14.5 HP single cylinder OHV gasoline engine has episodes of severe smoking when
When what if you are saying when starting..after sitting..the oil from your overhead valves are seeping into the heads through open valves..when not running..most likely bad valve stem seals...
Apr 12, 2014 | Briggs & Stratton Garden
Model 331877 briggs fuel pump leaks oil out vent
I just got done repairing the very same engine with the same syptoms that you mentioned. I had considerable oil coming out of the fuel pump breather hole (copper colored mesh). The source of the problem: a blown head gasket. This will cause the piston, in the compression cycle, to pressurize the crankcase through the head gasket leak into the valve lifter chamber and push oil out the vacuum tube (bottom hose) leading to the fuel filter . To fix, you will need to first disassemble the cylinder head from the engine. To do that you first need to disconnect the three hoses to the fuel pump. Remove the cover to the air filter, remove the air filter and the screw in the bottom of the filter housing. Remove the four bolts attaching the plastic flywheel cover and remove the cover., remove the cylinder head (8 bolts)and check the head gasket to confirm it is blown (you will probably see some dark brown or black discoloration of the head gasket between the cylinder and valve lifter chamber. Carefully remove all old head gasket material from the block and head surfaces and clean the head bolts. If either your cylinder head or block surface looks ugly, you may need to get them resurfaced (flatness tolerance is very small ) Buy a valve gasket set (contains the head gasket and other needed parts)
Remove the valve rocker arm cover (4 bolts) from the head. Mark the exhaust and intake lifter rods (they are different) Clean the combustion chamber. If your engine has many hours on it, you will want to remove the valves and check the valve rims and seats for wear or pitting. You may want to hand lap the valves to insure they are seating perfectly.
I coated my head bolts with an anti-sieze valve lube compound. The B&S service manual calls for this. Reassemble head and torque head bolts to 220 in.-lbs. (4 stages) Do very accurately. Compress valve springs, install push rods and set clearances between rocker arm and end of valve stem. Turn flywheel to move piston so that both valves are closed before setting clearances. install a new fuel pump on the plastic flywheel housing. I removed the breather from the top of the engine (two small screws) and checked the reed and oil drain hole, and resealed the breather cover (you will need to pull the flywheel to get to one of the breather screws. I used a gray high-temp rtv liquid gasket compound to reseal the rocker arm cover and breather body. Reassemble all parts and screws and use small torques as listed in Briggs Service manual. I put in a new spark plug, changed the oil and filter, and breather tube, and o-ring at the bottom of my oil filler tube. That should do it
Aug 03, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My 24 hp Briggs v twin smokes and uses oil bad. Smoke comes out of the left side when running. Can I use head gasket sealer to get me through the season?
There is no sealer that will resolve a head gasket issue, if that is what you have going on. and, if the head gasket failed remember it is a victim and not the cause, something else in happening.
I suspect that you have a compression related failure, based on the oil consumption and the smoke is probably blow by. This issue requires surgery to diagnose and fix.
Oct 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
May 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,219 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
