Question about Whirlpool Microwave Ovens
Runs but will not heat - Whirlpool Microwave Ovens
  • Whirlpool Master
  • 8,404 Answers
Check the door safety interlock switches for proper operation. These switches tell the oven if the door is open or not. If they have failed, the oven thinks the door is open and will not allow the heat to come on.
Thanks for your question @ FixYa.com
Posted on Apr 11, 2011
My microwave over just stopped heating but runs like it is heating
hi , now that's either power supply to power the magnetron or the magnetron itself ...
Regards
Rob
Jul 15, 2015 | Kenmore Elite Microwave, Model...
GE spacemaker GL1800 runs but does not heat
For that sound it will need atechnician but for not heating you cqn replace fuses
Sep 13, 2014 | GE SpaceMaker Microwave Ovens
Microwave runs but doe not heat
follow this test and fix it. God bless you
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 26, 2013 | GE JVM1190 Microwave Oven
Microwave not heating food model MA795B
1 door interlock
2 diode
3 magnetron
4 heat censer
5 dry joint on relay on timer board
6 Re: Jeff
Apr 12, 2012 | Goldstar Microwave Ovens
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Microwave runs, turntable turns, fan runs, but does not heat,
No heat means the magnetron circuit has failed. It is the part that generates the microwaves to heat the food. Usually not worth fixing since the magnetron costs nearly as much as a new oven. To diagnose, if the oven is on, you will hear a loud buzzing sound if the magnetron is shorted.
Jun 30, 2010 | Sunbeam SMW777 Microwave Oven
Microwave runs but doesn't heat
Most likely shorted the transformer for the magnatron,Its expensive to repair and you should consider just replacing the micro.
Jun 01, 2010 | Microwave Ovens
Microwave not heating...power going to it...turntable runs, lites on...no heating
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capicitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
