Question about Ludwig LG8B2 Industrial Sewing Machine
We have a brother TZ1/B652 it goes to fast can i slow it down
Can you get a foot pedal for this machine that goes slow for beginners?
not needed just do not push down all the way . putting a door stop wedge between the top and bottom could help a lot
Nov 22, 2017 | Sewing Machines
Question about Brother Sewing Machines Brother XL-2230, I can't thread the bobbin! I watched video on U-tube and it's same steps I've used. Bobbin turns very slow
Winding the bobbin:
be sure the thread goes clockwise all around the bobbin tension. It will cross itself before it heads toward the bobbin winder mechanism.
Brother XL 2230 Operation Manual Threading The Machine Winding The Bobbin
Place the bobbin into the bobbin holder so the thread will unwind counter-clockwise. Push the bobbin down. Pull the thread toward the front of machine (toward you, into the slit and then doubleback to the left through the tunnel and then through the opening.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjc86eA1tLVAhUi5YMKHdX6CHsQFggmMAA&url=http%3A%2F%2Fdownload.brother.com%2Fwelcome%2Fdoch000293%2Fxl21202220om01en.pdf&usg=AFQjCNHEtjx1a5wDJj3C0QthQNidYp8e7A
How To Thread Bobbin and Thread Sewing Machine on Brother LX2500
Different machine, but the bobbin threading is similar:
How to Thread Brother Sewing Machine
Aug 11, 2017 | Brother Sewing Machines
Stitch length for Brother TZ1 B651 zig zag sewing machine
I wish that I would be more helpful but here's what I can tell you. Digital programs offer the "format" to use. It will give a choice of millimeters or inches. You can also change the format choice after you have started your project.
Oct 03, 2016 | Brother Sewing Machines
Sewing speed not properly working
no known fixes just replace with new
Feb 19, 2015 | Sewing Machines
Why My se 400 sens I bought it it's running very slow
look for the speed control knob. turning that should make it sew faster. usually it is quite big.
Jun 06, 2014 | Brother Sewing Machines
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
My machine is too fast, i've tried gently pressing on the pedal, I've even opened it up and tried gently sliding the activator along but this doesn't help, it still seems to just hit top...
According to the manual, there is no speed control on your machine. It is apparently built into the foot control unit. I suspect something is haywire with the foot controller but would suggest taking the machine and foot control unit to a sewing repair service.
Mar 07, 2018 | Brother XL-2600I
Bobbin winder does not wind evenly. how do i fix this problem
Slow down when you are winding the bobbin. You are going too fast and it will always be uneven when you do that.
Dec 28, 2010 | Brother CS-6000
I actually have a Brother XR40 sewing machine (not XR35). I get a nice stitch on the bobbin side of the material, but not the top. The top is more like a straight thread anchored down and not a nice...
check to see if the needle is bent-roll it on a flat surface & see if it rolls correctly
if the needle is warped it will make a popping sound when it goes thru the fabric
check to make sure the tension is correct
check to make sure the thread is not catching on anything
I went to the brother website they have a manual in pdf format you can download for free
1.go to brother website
2.click on home sewing & embroidery
3.on the page on the left go down to product manuals &
click on it
4.on the page it will show home sewing & embroidery &
select model----xr40
5.click on view
6.go toward bottom of page-YOUR RESULTS-USER MANUALS
ENGLISH & SPANISH
7.click on user manual-english & spanish & the download will start- if you have fast internet it will take a few minutes
slow will take a little while
Sep 01, 2010 | Brother XR-35
The pressure foot will not run the machine you have to push very hard the the machine goes very fast.
meed a little more info, make sure the pressure foot is in the down position,
what do you mean you have to push very hard, are you pushing on the fabric to fo under the needle,
if the presure foot is down, check the manual on how to adjust the pressure it may be to tight and need to loosen it
Aug 27, 2009 | Brother LS-1520 Mechanical Sewing Machine
Ludwig LG8B2 Industrial Sewing Machine Logo
201 people viewed this question
Top Ludwig Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Ludwig Sewing Machine Expert? Answer questions, earn points and help others
