Question about NEC Office Equipment & Supplies
I received a file from someone who scanned a document and it was saved in a .nrf type file extension. She sent it to me an I cannot figure out how to open it. Can you help
  • NEC Master
  • 32,281 Answers
Your friend has scanned the document wit a NEC scanner.
You cannot open this image file without the NEC scanner program.
I suggest you contact your friend and get her to use the NEC scanner program to save the image as a jpg (JPEG) image file and then sent it to you.
Posted on Apr 11, 2011
  • Harold L. Scherer Apr 11, 2011
    Duh.... If I could contact them I would. This is does not explain how to open this file.
    President:
  • 1,623 Answers
You will have to contact them and ask them to save the file as a image file instead, the only way , that i know how to open that filetype is by using NEC's scanner software, which created it
Word docs sent as email attachments are arriving in my inbox as png files - useless. How do I change this please
.PNG stands for "Portable Network Graphics". Sounds like the sender may have scanned the document, and sent the scanned document to you? Scans will come out as either .png, .jpg, or .pdf formats.
If the file is a .png, you won't be able to edit in MS Word.
Another thing to check - Make sure when you are working on a Word Document, you are saving it as a .doc file.
  • Open MS Word Document
  • Do your editing
  • Click on the "Fille" button, and then select "save as" option
  • In the window that appears, next to the "save as type" wording click on the down triangle to see different formats to save. Select ".doc"
Bottom line... tell whomever is sending the emails with attachments, to send you the MS Word file, not a scanned file.
Jul 26, 2014 | Dell Inspiron Computers & Internet
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
Feb 28, 2011 | HP Office Equipment & Supplies
How to convert scanning documents to MS-words
You are going to want to find any OCR software that works for your printer. OCR is 'Optical Character Recognition'. It will take the scan and convert it into a text document, which is either already compatible for MS Word, or easily converted itself.
Feb 24, 2011 | Office Equipment & Supplies
Document received but unable to be opened / read
If you have MS Word 2007, by default, the file extension is .docx and it can't be open by previous versions of MS Word unless conversion packs are installed. To make your scanned documents accessible to others, save it using .doc extension. You can do so by following these steps:
  1. Click on file (round button) then Save As
  2. Save your document with compatibility with Microsoft Office '97 to 2003.
  3. The file extension will be .doc and you should be good to go.
Mar 23, 2010 | Epson Stylus CX3200 All-In-One InkJet...
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
2.select scan setting
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Scanning a document and attach it to my email
Just scan the file, use save as, choose file type,name and then location to save file, to (folder) you created in My Documents ,ie; Temp (folder).Later when sending e-mail attach file to message by clicking attachments browses to My Documents, Temp click file then attach file.It is now attached to your message.If you can save as PDF file do it ,it will be easier for person receiving.Good Luck.
Sep 09, 2009 | HP DeskJet F380 All-In-One Printer
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
I have sent a word document created in vista, and have sent it to an XP user. They cannot open or view the document. How do I change the settings in Vista to resend the document?
You need to make sure that the file extension is correct, for example .doc because there are others that a .docx extension as well. One thing is that make sure whenever you are saving a word document try to save it as Word 97-2003 document, in that way it can open to any other Microsoft Word application without thinking what kind of operating system does the computer have.
Oct 30, 2008 | Computers & Internet
Scanning a document
Hi
Easiest way...
1. Choose SCAN
2. Then SAVE AS *remember where you saved file.
3. On the FORMAT options when saving choose "JPEG"
4. Open your email and choose ATTATCH A FILE
5. Choose FILE from where you saved it
6. Add your text to email and click send email.
7. If you want to check FILE was sent
8. Click on Email SENT you should see it.
Good Luck let me know if it solved it for you !
Thanks
Tinteiros (Ebay)
May 01, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Scanning as file type Microsoft Office Document Imaging File, but sometimes it saves it as TMP file
tmp are temporary file type . Something has interrupted the scan before the file was completed and a tmp file has been created.
http://filext.com/file-extension/TMP
have you got enough hard drive space ?
make sure the recycle bin is empty .
Jun 22, 2017 | Fujitsu fi-5530C Scanner
221 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
