Question about Whirlpool LER4634J Electric Dryer
It heats and turns but it taking to long to dry clothes
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 11, 2011
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dry takes a long time to dry cloths
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Kenmore Dryers
Needs two cycles to dry clothes!
May 19, 2012 | Kenmore Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
237 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
