Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Only runs with choke about three fourths way out. cranks good on first start, but if you kill engine and return shortly it will not start. Turns over but no start.
  • 608 Answers
You have a fuel supply or carby issue
Posted on Apr 11, 2011
01 chevy malibu it starts but after 3 sec turns off fuel pressure guage says fuel pump is workin we even by passed tha theft system we changed the crank sensor and fuel pump relay any other ideas?
Hi Kaitlin:
3 seconds is a brutally short time to have the engine run. That's almost the same time that it takes to crank it over to try to start it. Is there any chance that it is actually stopping firing when the key is allowed to return to "run" from the "start" position?
If you have fuel, and you have spark, it will run. It sounds like you have fuel available, so unless the injectors are not triggering (bad sensor or wiring) something is killing your spark. Try checking each component separately and you should find which one is giving you grief.
Mar 31, 2015 | 2001 Chevrolet Malibu
Starting problem wont start on choke
You need to explain a little better... do you mean it will only crank properly when the choke is open and the throttle is closed ??? Has the battery been properly charged and tested ??? ( be honest here because we can't help if you don't ) are the battery cable connections is good shape ??? Have you tried spraying some carb cleaner into carbs when cranking ??? I have the same engine on my Triumph
Nov 26, 2013 | Triumph Motorcycles
Sym red devil feels sluggish
Instructions
    • 1 Locate the red button on the top of the handlebars. This is called the "kill switch." When you pull it up the engine can run; when you push it down, the engine will shut off immediately.
    • 2 Pull the kill switch up.
    • 3 Turn the key to the "on" position.
    • 4 Make certain the cord running from the key is attached to the steering column. This device acts in the same manner as the kill switch - the engine will run only when it is secured.
    • 5 Pull the start cord, which looks like an enlarged lawnmower pull-cord and is generally found on the right side of the machine.
    • 6 Listen to the engine - if it starts, let it get going slowly . If it "pops" but does not continue to run, try pulling the start cord a few more times. If you do not hear the engine turn over at all, proceed to the next step.
    • 7 Find the pull tab under the right side of the handlebars. This is called the choke - it often has a circle with a diagonal line through it. The choke helps to start an engine when the weather is very cold or the machine hasn't been used in a while. When using the choke, try leaving it on only long enough to hear the engine fire a couple times, then return it to the "off" position. A choke left on too long can flood the engine.
    • 8 Place the choke in the vertical position - this is called the half choke position. Pull the start cord several times. If the engine fires up, place the choke back down to its original position and let it slowly warm up. If the engine still has trouble starting, proceed to the next step.
    • 9 Pull the choke 180 degrees from its original position - this is called the full choke. Pull the start cord until the engine sputters a couple times.
    • 10 Replace the choke to the original off position and continue to pull the cord. The engine should fire up and settle into a steady hum, ready for fun in the snow.
Jan 15, 2013 | Motorcycles
Instructions
Jan 15, 2013 | 2008 Sym Jet Red Devil 50
Lt1000 won't start
First thing I do, see if you fuel. Remove fuel line from carb. Second check your choke. See if linkage moving enough. Third it on start. Fourth see if had spark. Remove spark plug, then plug it in coil wire and hold base of plug against the bare spot on the engine. Still if doesn't run return. Good luck.
Nov 25, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a 2006 XL1200C. After hitting the kill switch, the bike jugged and choked before the engine stopped. When I went to start it up again, I heard a click from a solenoid (I believe) and all of the...
check your ground cable first. I think I'd start at the battery. Remember.... Harleys vibrate alot! Main wiring would be my first thought. It's happened to me more than it really shoulda! Good luck
Sep 07, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Engine turns over won't start. There is no spark
Poss saftey interlock switch failure. Bad ign coil or the harness has shorted to ground Unplug the kill wire from the coil and if fire "spark" returns then u know your coil is good. Hope this helps
Nov 19, 2009 | Husqvarna Garden
My 9N is having trouble starting. It turns over fine but seems to be flooding. When it finally sputters to a start, it takes a while to run smooth. Also the idle seems to be fast and there is no change in...
Shut off fuel to carburetor, drain carburetor. Open fuel and count to three then shut off fuel. Crank engine then pull choke for 1 second then push in. If engine starts open fuel valve at tank. Also try lowering float level in carburetor. Good luck.
Jun 26, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Replaced stop switch and it still won't shut off!
While attending college, I worked at a tool rental center and learned many tips and tricks from the mechanics. The problem that we heard the most from customers was that the machine would not start. Your your machine at least starts and runs fine, however will not shut down with the factory kill switch. Many times when replacing the mag. (spark coil) the kill wire would rub against the flywheel and break or over time the conductor wire will break inside the insulation. If you kill switch only has one wire, then all the kill switch does is short the mag to ground. Simple test is to remove spark plug, re-connect wire to plug, touch plug to engine and pull rope to observe spark, then short the tab on the magnito to ground, should be no spark. If you still have spark, coil is defective however good enough to run engine. Kill with choke or pull wire. If no spark with test, make new wire from tab of coil to kill switch or any switch that will short tab to ground. Good Luck
Jan 03, 2009 | Briggs Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
43 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
