Question about Tom Ford TF 9 Sunglasses
My glasses' leg broke and i would like to get them fixed. where can i call?
How to fix crack in the slide
You might be able to use Fibre glass and fibre glass resin to cover the crack.
May 02, 2016 | Castle Little Tikes Climb and Slide Castle...
I need to purchase legs for my nike flexon 4083 eyeglass frames. color 718. I do not need anything more than the legs. I paid well over $600 for these frames and have had to resort to crazy glue for...
Hi Curtis,Did you ever find any arms for your glasses? I have the same frames in the 718 color with a 140 length arm that the nose/bridge broke on.BC
Jul 10, 2011 | Nike Flexon Sunglasses
One of the legs of the sunglasses broke off. The hinge is still attached to the leg of the sunglasses.
You may need to replace or rescrew on the other leg, usually done using a small glasses repair kit.
Apr 19, 2011 | Lacoste Clothing Accessories
I broke my passanger side mirror. I bought new
REPLACEMENT GLASS IS AVAILABLE AT YOUR DEALER SHIP AS THIS CLASS IS A CURB GLASS AND NOT A FLAT GLASS AND FITS PERFECTLY.
Jul 15, 2009 | 2008 Hyundai Elantra
The glass is broke, can it be fix?
You actually broke part of the LCD Screen, you can replace the screen (or pay someone to do it) I would look around on eBay and see if anyone has a good screen for cheap.
Good Luck!
Dec 05, 2008 | Garmin GPS
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Tom Ford TF 9 Sunglasses Logo
278 people viewed this question
Top Tom Ford Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Tom Ford Clothing Accessory Expert? Answer questions, earn points and help others
