My food keeps freezing eventhough the temp setting has been set to the lowest. i have a whirlpool WRID45T fridge. Pls help... thanks.
  • 413 Answers
Sounds like the thermostat could be sticking shut. You may have to change it out.
Posted on Apr 11, 2011
My whirlpool fridge is freezing the food in it. What can cause that and how do you fix it?
set at minor temperature,set the thermostat dial at warm temperature.maybe its a little bit empty of food and at full coldest settings
Jul 15, 2014 | Refrigerators
My whirlpool fridge is freezing the food in the fridge. What is causing that?
adjust the temperature settings.change from coldest to colder
Black and decker mini refridge freezes food on lowest setting
The lower the setting the colder the fridge should be, the dial should be turned to the right. A refrigerator should be kept around 35-36 degrees F
Jan 03, 2012 | Food Processors
Food freezes in the refrigator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
May 20, 2010 | Whirlpool GD5SHAX Side by Side...
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
