Its nothing to do with the wires it wont boot up from my hardrive and when i go into my bios settings its saying that i havent got full acess to it please help thanks
  • 27,725 Answers
You will have to make yourself the adminstrator
click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control also you can change the password there
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
Hope this helps
Posted on Apr 11, 2011
Cant boot up EMachines T3882 no quick boot and f8 does nothing, what do i do?
If you can't get into the bios, you can't start a repair, when it's booting, continually press F2 to get the bios up, if that does nothing reboot an continualy press Del, this is for the bios menu and set the cd drive as first boot device.
If not continually press F8 on boot up this is safe mode, then when youre in highlight last known good configuration and press Enter.
Give this a try as your pc will not be set to boot from cdrom as default and will just try to boot into windows.
Sep 12, 2012 | E-Machines eMachines Desktop PC
Inaccessable boot device
I really don't know what you mean. Give all the specs of your PC , please also make sure your HDD is not set in your BIOS to RAID, Set it to IDE Mode
Jun 08, 2010 | Intel ASUS P4S800 Motherboard REV. 2.01...
My computer says: DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. How do I fix this problem. There is a screen before this, but then it turns straight to that screen and will not allow me to do...
1. Check the hardrive cable connection (data and DC supply).
2. Under the BIOS setting, make sure that the hardrive is detected (set to enhance mode), this will detects either SATA or PATA., Exit and Save new setting
3. If still no detect, your hardrive might defect n need new one
Apr 26, 2010 | HP Pavilion MX70 17" CRT Monitor
Bios not recognizing new hardrive
Hi:
Some older laptops don't always recognize the full size hard drives bigger than 134 Gb, but they usually show up in your bios. There isn't an easy way to install it wrong, so if the drive wasn't new to you, it might have a problem...New Hard drives come with installation CD's, but that won't do you any good until the drive is recognized
Nov 24, 2009 | Office Equipment & Supplies
NEED WIZ"S HELP- CANT BOOT XP OR VISTA CD FROM DVD DRIVE
I'll give a whack at this problem. I think the previous person meant blank drive NOT black drive (that doesn't make sense to me).
I would follow the previous persons in going to BIOS and making sure the first boot device is CDROM. My question to you is whether you've already done this or whether you need assistance with this process. If so, please tell me what computer model you have.
Dman
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Cannot boot windows xp
Test the CMOS BATTERY..TO MAKE SURE ITS GOOD IF NOT REPLACE.If it test good leave out for 5-10 minutes replace.motherboard bios should now beat default settings.reenter the bios.move cd to first boot.save changes.if you do not save changes it will not work.place.computer should now boot from disk.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | EliteGroup P4M800-M7 Motherboard
Want to reinstall to factory settings
As the pc is booting press F2 or Del (dependant on bios) and enter bios set up.
Choose to make your cdrom as first boot device, save settings and exit bios.
Insert cd drive before the boot up starts and there will be a screen prompt to "press enter to boot from cd", press enter and then the cdrom will go to the next step, asking press 'R' to repair or press 'Enter' to format and install windows, choose repair if you have documents you need on your pc.
The system will then go through a full repair installation, when complete your system will be repaired and everything should be as before with nothing lost.
You may have a faulty hard drive so if you cannot get windows to repair it will tell you theres no drive found.
Sep 10, 2008 | Toshiba Satellite A105 Notebook
Problem in acer aspire 5630
- is the BIOS set to boot from the hard drive ?
- have u changed any drive setting in BIOS (sata mode, pata mode ...)
- try to boot with a linux live cd, or with the vista dvd and see if they can see the drive ... if thay can, than most probably a reinstall of the OS would fix the problem, if not , check the BIOS settings, also make sure that the drive is properly fixed in it;s place, if posible test it on another laptop to be sure if it;s causing the probems or not ...
Jun 28, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Vista Install Issue
This link has at the bottom of the page a bootable cd .iso to download.Burn this iso on cd and boot from it. or download GParted bootable ISO download and burn on cd and boot from there. Its like running FDISK on steroids.
You should configure sata in the bios boot options etc.
Mar 21, 2008 | Intel Motherboard
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
