Question about Canon LASER SHOT LBP-2900 Printer
I have problem while printing time it will struck on paper on center
    New Friend:
  • 140 Answers
Check your fixing unit. and toner cartridge.
Posted on Apr 11, 2011
Does not print, paper is struck off, shows red light
Struck off , needs your explanation on Struck off
Mar 14, 2015 | Office Equipment & Supplies
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Print head is stuck to the far right of the printer I have had problems in the past with the head cleaner popping up and stopping the print head from going home but now it has I think come loose and...
Hello and Welcome to FixYa!
Sir, In Epson Printers if print head is struck and it don't move then it may be because of several reasons.Mostly problem of print head struck is because of Paper Jam, actually their may be small bit paper jam in side the printer head,There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and it struck the Print Head.Open printer cover and check to make sure no paper or foreign objects obstructing the printer feederIf you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.It will clear the printer jam and it may allow you to move print head.
If problem still exist then it may be due to dirty or clogged print head which hinder a regular flow of ink from the ink cartridge to paper. The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head and print head struck because of it. This problem can be solved if you clean the print head with software, There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printers software that will actually clean your printer for you. You can use them to clean it, After cleaning it may allow you to move the print head.If the built-in cleaning functions don't seem to do the job then There are a few ways to clean your print head manually. Its technical because you need to open the Printer, First remove the ink cartridge from the print head and take the print head out of your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it's really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle,This should get rid of any dried ink that was loosened during the soaking. Be careful, especially if you use isopropyl alcohol to clean your print heads, Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out.This process surely helps you but its highly technical so i recommend if your product is in warranty or out of warranty.If your product is in warranty, Simply contact to Epson Service Center or from where you purchased it and claim the warranty. Your problem will be solvedI hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 30, 2011 | Epson Stylus C88 InkJet Photo Printer
There has struck in second paper when I printing more than one pages. Help me
Sometimes the paper, like money, will stick when printing. It's just the paper.
You may need to feed your printer the paper one page at at time until you get some new paper. The thinner the paper stock, the more likely it will stick to each other when printing.
Try getting some thicker paper (paper weight) when returning to the store.
Jan 21, 2011 | Canon LASER SHOT LBP-2900 Printer
Paper struck
Fusing rollers are not turning, Grease the bushings / bearings.
Perform Shipment Set.
May 27, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Papaer jam
same thing happens to me
May 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper wiil no feed
I am also having the exact same problem. I have to print things 5 plus times until I get it straight on the paper. It pulls pretty bad. I wish someone could tell ME the solution.
May 04, 2008 | Lexmark X3470 All-In-One InkJet Printer
Canon LASER SHOT LBP-2900 Printer Logo
22 people viewed this question
old marine
old marine
