Question about Cobra 18 WX ST II 40-Channels Base CB Radio
There isn't enough audio, how can I turn it up?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Install a computer "Amplified" speaker to EXT SPKR. The computer speakers run off 12 volts. Most do--then crank it up loud as you want. If output is not loud...go to Defcom radio mods.
Posted on Apr 11, 2011
How to fix your heater in a 2005 mone carlo
I would need some more clarification to get you a 100% answer but based on some assumptions I can give you 2 possible solutions.
It is possible your blower isn't working. You going down the high way is getting enough air through the venilation to bring heat into your car. If this is the cas while you are parked turn your blower setting down to the lowest point. Listen then turn it up to the highest setting and listen again. If you don't hear a fan running on the highest setting you need to replace the blower.
The other possibility off the top of my head is a bad thermostat. Your car isn't getting hot enough to trip it until your on the highway. If this is the case simply replace the thermostat.
Oct 20, 2012 | 2005 Chevrolet Monte Carlo
No sound
Make sure you do not have "mute" turned on. Also, on some TV sets, you have the option to turn off the internal audio (your speakers)and enable the audio out terminals. Make sure that this isn't the case. Outside of this, you could be looking at a internal failure.
Sep 03, 2012 | Televison & Video
AC clutch not engaging fuse or frozen clutch?
You could find out if the clutch is frozen or not by turning it by hand. Engine off. If not frozen it could be the fuse or it could be that there isn't enough refrigerant in the system. Also it is possible tHat the switch isn't working, check the relay too.
Jun 18, 2012 | 1996 Dodge Caravan
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
2005 jeep wrangler unlimited starting [problem, replaced the starter, ignition switch but problem is still there. Starter will stay ingaged but not long enough to start the vehicle. After several tr
There are several things you need to check. Start by checking the alignment between the pinion gear of the starter and the flywheel. If that is loose or binding the starter will do this. Next, check teh starter relay to make sure it isn't faulting out. finally, if you have an Alarm installed, cut the power wire to the alarm or pull the fuse to make sure it isn't the Anti-Theft circuit malfunctioning and stopping it from starting.
Oct 25, 2011 | 2005 Jeep Wrangler
We are considering purchasing the Onkyo NR 509 but have been told that there are major heat issues. Since it will be inside an enclosed cabinet, we have some concerns. Is this an issue we should be...
according to the reviews Ive read on this receiver, your right, they have a major heat problem in the output transistors,, the heat sink isn't large enough to keep them from going out or they aren't large enough to handle the power, people have even tried adding a computer fan to the area of the transistors with no good results
Jul 23, 2011 | Onkyo HTR500 Receiver
I Have an spl audio amp 520 watt and when it turns on it automatically goes to red which is protect. what could be causing this problem
It could be 3 things. There could be a short somewhere, your ground isn't strong enough, or you accidently switched up the ground line and the power line on the amp. Since the fuses aren't blown I would say that your ground isn't strong enough.
May 01, 2011 | SPL Car Audio & Video
Sound seems to coming from only one of my front speakers(left side). what am i missing? I can't seem to find a balance setting on the menu
Traditional Balance Controls are gone with the dinosaurs of stereo audio equipment.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Adcom-GFR-700-Receivers-manual/id/582dj599/t/2/
You may just have a speaker or speaker wire loose/failing. Swap them to isolate to an internal or external failure.
There isn't enough adjustment in the setup to make any channel completely silent.
Use test tones to diagnose it. Page 36.
Apr 25, 2011 | Adcom GFR-700 Receiver
Cobra 18 WX ST II 40-Channels Base CB Radio Logo
93 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
