Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38 Degrees, but currently at the actual temperatures are currently 14 degrees in the Freezer and 47 degrees in the Refrigerator. (a few hours ago it was 9 degrees and 44 degrees, so its dropping, not cooling).
  • 661 Answers
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Posted on Aug 03, 2017
  • 75 Answers
SOURCE: Freezer not staying cold
thermistor has worned out so please change the thernistor then you ll find the temperature gets maintained in 0 degrees......
Posted on Sep 10, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (
Posted on Apr 28, 2009
SOURCE: The tempature is set for 38 degrees, but the
Chartigan - had this problem with my 1998 642 about 5 years ago, and had to have the condenser coils replaced twice- because the refrigerant was leaking. warning signs are: temp is more than 37 degrees [ get a fridge thermometer to monitor], food seemed to spoil quickly, and frequent notices from the display bar to clean condenser . after cleaning it 3 times in a month, when i called the service center they said that warning actually means"call service center" - arrrggghh the manual sure doesnt say that! anyhow - just something to consider, and hope your problem is not this serious.
Posted on Aug 23, 2009
Veg and fruits freeze up.. Why? and what should temps be for frig and freezer?
We had this problem almost 4 yrs ago. It was the damper assembly which is a common problem w/ GEs. A damper is a door flap that opens and closes between the fridge and freezer that allows cold air into the fridge to regulate the temperature. Eventually, it breaks, allowing in too much cold air into the fridge, thus making both sides a freezer! Fixya's link that helped me is this one, which is very helpful: You also might need to enter a diagnostic code when you replace it. Check this out also: Don't let the description of the fridge as a GE Arctica mislead you. These are different models, but internally are the same components.
Jun 14, 2014 | GE Adora DSS25KSTSS Stainless Steel Side...
Refrigerator is too cold even when adjust the temperature
Too much freon? Or maybe you got the controls mixed up. My refrigerator used to freeze a gallon of milk over-night.
Nov 18, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
My food is freezing in the refrigerator section. It is a GE adora
yes try lowing your number on your t-stat knob. and also the other knob should control the amount of cold air coming from the freezer to the ref. u want to make freezer colder that makes ref. section warmer. and that help. try this ok. later gator.
Feb 17, 2011 | GE Adora (DSF25KGTBG) Side by Side...
I have a GE Adora M# DSF25KGTABG. Set temps on the freezer door to 0 and 37. runs great for a few days then drops down to -9. I have replaced all thermistors and the mother board. What would be the next...
I have the GE Adora DSS25KSTB ss and the temps will not hold to cool temp.
We set it at 0-25 and the refg to 35 and sometimes it will cool to that temp and then sometimes it is a lot warmer.
Dec 29, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
What is causing the items in the vegetable bin to freeze and the ice maker is not working,(ice melted in the bin) and the water dispenser is not working and the filter was just replaced a week ago /
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Oct 05, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
I opened the freezer and freezer is not freezing, I found ice on the back wall .Both freezer and fridge will not cool. I tried to reset it now.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Sep 01, 2010 | GE Adora (DSF25KGTBG) Side by Side...
My GE Adora freezer section constantly gets down to -5 to -9 degrees, when the setting is 0.
I would advise replaceing # 4 AND # 5 thermistor . The # 4 , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils ( remove the inside rear freezer panel ) , with 2 white wires going to it . Part number WR55X10025 for both . The # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jun 13, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
I'm having problems with my Adora fridge. First, the contents in the crispers started freezing. The storage tank behind the drawers seems to be frozen. Now the water won't dispense. Ice is being made...
Your model has a WR60X10132 or 10055112 Damper and Fan that regulates temperatures between the freezer and fresh food compartment. The part has been recently updated. Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator.
(The manufacturer has replaced part number wr60x10132 with this item, part number WR49X10091.) (Manufacturer part number WR49X10091 is RepairClinic item number 1055112.)
BRB with photos and locations. Sea Breeeze
Jan 23, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
