Question about Toshiba Televison & Video
The convergence colors are mixed up - Toshiba Televison & Video
  • Anonymous Jan 31, 2009
    the convergence colors are mixed problem
  • Toshiba Master
  • 8,617 Answers
I will need your model number of your Toshiba to help you. Please reply to this same post with your model number.
Posted on Aug 07, 2008
If looking directly into screen you see all three lights Red Green Blue next to each other illuminating parts of the screen that color.
U mean on tv screen colors lines R,G,B colors are all mixed up and mis alignments all those R,G,B colors lines on the tv screen?Yes,u have colors shadow picture or 3D picture look alike?Yes,ur tv have a problems known as a convergence problems,it is dead.This tv convergence board it is dead must require replacing 2 STK of convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv picture convergence problems.The shop will cost u like $300-350 for parts and labors.
Jun 22, 2011 | Panasonic PT-52DL52 52" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Cannot set color, tried but just not good viewing!
Have colors shadows in mix,mis alignment colors lines R,G,B or 3D pictures?Yes.The tv have a problems known as a "Convergence Problems",it dead.The tv convergence board require changing parts.Must have it 2 STK Convergence ICS and some or all it resistors to be replaced to solved the convergence problems.The shop will cost u $300-$350 for parts and labors.
Jul 26, 2010 | Philips 60PP9202 60" Rear Projection...
The colors are mixing togather
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Televison & Video
Mixed colors
Souns like convergence problen. If you can't align it. Likely convergence ics need replaced.
Apr 24, 2009 | Televison & Video
Converge problem
That sucks. I just did my convergence and now I am having mixed colors that I have to adjust. Sucks, Good luck!
Mar 29, 2008 | Philips 60PP9202 60" Rear Projection...
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
61g9uxc Toshiba Rear Projection Convergence Problem
ronniezay,
Don't replace the convergence board, but take it in and have the convergence amps replaced. That unit takes two stk392-110 IC's and are fairly inexpensive compared to replacing the entire module. In fact, ask to have them replaced with a more reliable stk392-150's...
Bill
Nov 05, 2007 | Toshiba 61HX70 61" Rear Projection...
Tuning
E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970
Mar 19, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
