Question about HP Computers & Internet
The monitor comes on & display comes up which states VGA INPUT No input signal then it tells me monitor is going to sleep
  • 37 Answers
Check the monitor cable or something else is not ok with the computers video card
Posted on Apr 11, 2011
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
When tryong to install monitor the computer starts but the monitor only show fujitsu siemens logo and before I can see anything else it states no signal going to sleep. Have downloaded updated driver for...
Does the monitor have two inputs? (Digital - DVI, and Analog - VGA)
If it does, check on your monitor whether the right input is selected; there can be a separate button for input selection, or the selection can be made from the monotor's On Screen Menu.
Sep 26, 2010 | Fujitsu Siemens Computers & Internet
What is the parts of a monitor
Part Number:RK284AA#ABA
* Display Type LCD display / TFT active matrix
* Built-in Devices Microphone , Speakers
* Width 20.6 in
* Depth 11.4 in
* Height 18.9 in
* Weight 19.8 lbs
* Enclosure Color ( The image of the product displayed may be of a different color )
* Localization English / United States
* Display (projector) image aspect ratio 16:10
* Image Contrast Ratio 1000:1
* Diagonal Size 20 in - Widescreen
* Dot Pitch / Pixel Pitch 0.282 mm
* Max Resolution 1680 x 1050 / 60 Hz
* Max Sync Rate (V x H) 76 Hz x 82 KHz
* On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit
* Controls / Adjustments Tilt
* Tilt Angle 30
* Signal Input VGA
* Digital Video Standard Digital Visual Interface (DVI)
* Type Microphone|Speakers
* Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
* Connections - DVI-Digitaligital , - VGA
* Microsoft Certifications Compatible with Windows 7
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 65 Watt
* Power Consumption Stand by / Sleep 2 Watt
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 20 - 80%
* Service & Support Limited warranty
* EPA Energy Star Compliant Yes
* EPEAT Compliant EPEAT Silver
Feb 15, 2010 | HP W2007 Desktop Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Cpu says no input vga signal, then goes to sleep
The no input VGA signal just means that the monitor is not receiving anything from the graphic card on the tower. Is the card a digital (DVI) output card? You'll know by the connector, it's white and slightly wider than a standard VGA connector. If so, perhaps the monitor is set to the wrong input?
If that isn't the case, and the computer is using an on-board or built-in graphics controller, you could try resetting the system's CMOS settings by setting the clear-settings jumper on the system board, or simply remove the plug and CMOS battery for a few minutes. Check the computer's documentation on the exact steps to do this.
Hope this helps!
May 19, 2009 | HP GX613AA Pavilion A6300F Desktop PC
Computers & Internet Logo
96 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
