Question about Lincoln Impinger 1116 Gas Oven
Our lincoln pizza conveyor oven keeps shutting off, it cools down to about 290 degrees and then restarts why is it doing this and what can we do to fix the problem,? this has happened 3 times tonight and I am losing all my business tonight.
  • 17 Answers
SOURCE: lincoln pizza conveyor oven
have you checked the speed control?? it maybe off on the speed run some empty pans thru and time each one I will need a model to give you the entry and exit times for your model before we can futher. do it 3-5 times let me know
Posted on Dec 04, 2007
jmgldsmth
  • 1869 Answers
SOURCE: how to reverse the conveyor belt on a blodgett pizza oven
reverse the wires on the conveyor motor
Posted on Apr 22, 2009
  • 12 Answers
SOURCE: Lincoln Conveyor Oven - 1132
Switching phase on products are usually up to UL. You need a good tech and it can be done. If it is marked 3 phase and you make a single, the responsibility falls on the person that did the conversion. Components should be similar from 3 phase to single, just use OEM parts!
Posted on May 25, 2009
SOURCE: a loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Posted on Aug 21, 2009
SOURCE: Lincoln Impinger Pizza oven 1301 model number
hi,after i switch the oven on ( lincoln impinger 1157 ) the small flame and the big flame comes on and with in 3 second goes off again,i have checked the flam sensor ,air switches,relay,air blower but still same problem, anyone got any ideas? thanks Kamran
Posted on Dec 14, 2009
I have a licoln 1000 pizza oven it will cook outside of pizza not bottom why
check the fingers especially the bottoms ones , they could be clogged with dirt or pizza particles. just clean them
May 27, 2014 | Lincoln Conveyor Oven - 1132-080-A
Message saying belt jam and conveyar belt not moving
Error massage on display screen saying belt jam is as a result that the oven conveyor motor failure. If it does not move or function. The fault could be inside the motor circuit that contains hall effect sensor, the motor could be stack, or the controll boar may require cleaning wit dryclener liquids.
May 04, 2011 | Lincoln 1132000U - Impringer II Express...
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Apr 29, 2011 | Lincoln 1132000U - Impringer II Express...
Ovens conveyor belt is working, but the heat and air are not working
A conveyor belt oven would make things so much easier for the staff of a pizza restaurant . Is it possible to get a wood fired conveyor belt oven? If not .... could I build one?
http://www.cookbookclub.net/breakfast/breakfast-home.php
Apr 18, 2010 | Lincoln Conveyor Oven - 1130-000-A
I have a lincoln impeger pizza oven and it wont come on
The oven temp high limit is on the back. Depending on model there is a control box high limit that you need to open the control box and locate. If this is the case, make sure the cooling fans are running.
Dec 13, 2008 | Lincoln Conveyor Oven - 1133-000-A
Lincoln Impenger 1100
hellow my name is ash i sale linclion ovens and repair they have only one burner and they only go up to 600 degree F make sure that the impenger plates one on top and one bottem are possion prapley, 2nd set temp at 500 and 530 f time 6.5 m if still under cook blow use plates with holes
Apr 27, 2008 | Lincoln Conveyor Oven - 1133-000-A
Lincoln pizza conveyor oven
Dec 03, 2007 | Ovens
Lincoln Impinger 1116 Gas Oven Logo
59 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
