Question about Lexmark X1270 All-In-One InkJet Printer
Trying to print but, it keeps scanning, and the on button keep blinking instead of staying lit, what do I do?
  • Official Brand Answer
  • 3,344 Answers
Your printer probably needs to be reset. First, remove the sheets of paper from the feeder. Open the printer and remove the cartridges. Also check and make sure there are no obstructions in the cartridge carrier path. Close the cover. Then unplug the power adapter from the printer.
Wait at least 10 seconds before you replug the power adapter into the printer. When the printer turns on, reinsert the cartridges. Load some paper. Try to print again.
Posted on May 03, 2011
My monitor won't stay on
WOW another all in one problem. Looks like you are just about ready to be without a computer for a while. If you at least had things separate instead of being an all in one you could just plug another monitor and keep on rolling.
It sounds like either the LCD Inverter or the LCD Screen has issues.
Mar 31, 2012 | Sony VAIO VGC-LS20E Notebook
I have exactly the same problem as ammcgee What we can do? By ammcgee7 on Apr 20, 2011 My Nyko Wand for Wii will not sync properly. The two bottom lights for stay lit and device won't work at...
1) Open the battery compartment and there should be a small circular red button.
2) Next to the Wii's SD storage area there is a rectangular square button.
3) Hold down the red button on the controller and the red button on the Wii until the light on the controller stops blinking.
Sometimes it can take multiple tries to "sync" the controller with the Wii. Keep trying until the lights stop blinking.
May 07, 2011 | Nyko Wand? for Nintendo Wii
Lexmark X2350 All-in-one does not respond to anything. When i plug it into an outlet the power button lights up and stays lit for 10 seconds then blinks once and stays lit for another 10 seconds and blinks...
Your problem lays in to one of the output capcitors in the circuit board. To have it repaired would cost more than purchasing a replacement printer these days.
I would just purchase a new one instead
Jan 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
1996 chevy 1500 z71. Keeps blowing fuse when trying to use push button 4 wheel drive. Note: 4- Low and 4-Hi stay lit and blinking before fuse blows. New actuator. New switch on transfer case. New transfer...
Cheak all wiring, one little **** in the wire will make a fuse blow. I had the same problem with my starter and i replaced the starter but it was still blowing the fuse, come to find out it wus a wire burnt into so cheak all wires carfully.
Nov 09, 2010 | 1996 Chevrolet K1500
All lights stay lit when try to print. All the lights along with both ink lights. Have to press the paper feed button, it will shoot out a blank page then print the document. This is becoming very...
hi you can easily solve this problem
the printer lights are blinking it is a catridge problem
please use orginal priter Hp catridge or use any other catridge.
i hope you will solve ur problem
May 13, 2009 | HP DeskJet 9800 InkJet Printer
Keeps wanting to print alignment page
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 20, 2009 | Lexmark X2470 All-In-One InkJet Printer
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Wont find headset
Fold the mike boom to rear, push center football shaped button down for about 3 sec until it stays lit (not blinking) unfold the mike boom make sure it stays steady lit (no blinking) scan for bluetooth Walla!
Jan 02, 2009 | Motorola Mobility HS810 Consumer Headset
Cant print. the tear like button is blinking
I have a 6940 color printer and I am assuming the 'tear' buttons are the same. If so, it is an out of toner indicator.
Dec 05, 2008 | HP DeskJet 5650 InkJet Printer
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
