Question about Goodman Heating & Cooling
Have a question my air is not working there is no power gointo my furnace and my thermosate what can i do
  • 413 Answers
Usually, there is a switch beside the furnace that looks like a regular light switch. Sometimes this switch is accidently turned off resulting in loss of power. Also, if you have changed the filter or inspected the furnace and the doors are not on properly, power could also be interrupted. These are two typical problems you need to check first.
Posted on Apr 11, 2011
The heater turns on, but does not ignite. The fan runs for about 5-7 seconds then shuts off. I am assuming the heater needs a good cleaning?
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... I hv gas furnace we turn thermosate on upstairs but still wont turn on coud turn ...
Furnace Not Starting - Clean the Flame Sensor - YouTube
? 3:15
https://www.youtube.com/watch?v=Ecd5CzJjss4
Jan 4, 2012 - Uploaded by Home Improvement Videos
If you woke up to find that your gas furnace is not starting or it's ... If this sensor gets dirty (and they almost always do over time) then your furnace will try to light, ... working, you can hear it starting, but the burners on not coming on. ... The furnace nowcomes on every time and the house is nice and cozy.
Furnace wont start. What to do before calling the repair man ...
? 10:11
https://www.youtube.com/watch?v=yJxDc90hs4g
Sep 12, 2012 - Uploaded by grayfurnaceman
Our property manager is great about sending a repairman, but the house is a mess. ... While troubleshooting my downstairs furnacethat wouldn't turn on, I turned off the ... Not sure what to do now about flame rollout switch..
Jan 05, 2016 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Gas furnace does not come on
You should have 2 blue wires as well down at furnace connections. Remove thermostat wires going to those 2 blue wires and connect those 2 blue wires together, ( make sure they don't touch anything else) with thermostat on heat setting. If 12 VDC power going to red & white or red and black at furnace, connecting those 2 blue together, should start furnace. If not problem at furnace, if it does start, problem at thermostat or wiring to it. All that does is by-pass thermostat to confirm where problem is.
Jan 08, 2013 | Dometic Rooftop RV Air Conditioner
Goodman air conditioner not starting
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 04, 2011 | Goodman CKL42AR42 Air Conditioner
It says that the cool program is running but no air is coming out of the vents
there are a few things to look at 1) Power is on at furnace and condenser
2) Switch sub base to fan on and see if you get air. If that works and if there is air great. If no air check the furnace to see if the filter is plugged and or if the cooling coil is frozen If all is clear try this. 3) Shut down main power either at breaker or switch to the furnace and wait about a minute or so then turn on breaker or switch 4) If this fails you could have a controller board problem at the furnace or blown fuse. Without knowing the type or age of your system its either a board or relay provided power is good
Jun 08, 2011 | Honeywell Programmable Thermostat Heater
On my therostat it show and talks about the R wire and the Rc wire. What is the differet?
If you would have a two transformer system..... The power wire from the furnace transformer would hook up on R and the power wire from the Air Conditioner transformer would hook up to Rc....
BUT most systems now only have one transformer...... So if you are using this thermostat you will need to put a jumper wire from R to Rc. So the Air Conditioner will work. Furnace is the source of the transformer. R/Rc,W,Y, C, on the Thermostat will Hook up to R,W, Y,C on the furnace and Two wire from the Air Conditioner would hook up on Y and C on the furnace.....Good Luck.
Apr 02, 2011 | Heating & Cooling
My furnace is only cycling for a few seconds and shuting off then it will kick back on for a few seconds and turning off again .the trouble shooting said its the heat anticipator .and the problem is my...
Hi remove the front cover on your thermosat turn the power off first blow any dust of the mercury tube , you will see a round disc in front of you with small lever on it this what is called the anticipator you can adjust this moving it up or down ,
Feb 15, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
My pilot keeps going out on the furnace. We lite
Check the pilot light size. Is it small and not surrounding the top 1/3 of the thermocouple? If it isn't then the pilot orfice is restricted or the pilot tube compression nut could be loose. The pilot gas adjustment screw may also need adjusting if this gas valve has one. These problems should only be addressed by an experienced service tech.
Nov 09, 2009 | Heating & Cooling
2008 Jayco Eagle 31bhds furnace and air conditioner problem
check your power source coming to the unit. also check to mack sure you have the unit set for A/C if your air conditioning. Also on most furnaces there is a kill switch when you remove the doors, usually on bottom. make sure that button is pushed in, if not it will completly kill the power to everytihng.
Apr 22, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
