Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
I have a Kitchenaid side by side Superbra and it constantly humms. It sounds faintly like an airplane taking off. The problem is recent and we bought it new in 1999. Do you know why it's humming and can we fix it ourselves?
  • 552 Answers
You can fix it. You have a bad overload relay. This is the white box on the side of the compressor it plugs into the side.
Let me know
Posted on Apr 11, 2011
2002 grand am gt sedan right front clack, and popping when turning or slowing down
If you hear a clacking sound esp. while turning. Sound like your CV joints (constant velocity) or Front Wheel Drive axle.
Apr 13, 2013 | 2002 Pontiac Grand Am
How do you take off the ice/water panel on the front door of the freezer to make repairs?
YOU WILL MOST LIKELY NEED AN ICE DOOR KIT, THE EARS OF THE ICE DOOR BRACKET ARE BROKEN MOST LIKELY,
Jul 27, 2012 | KitchenAid Refrigerators
Where can I order replacement baskets for my Kitchenaid Superbra refrigerator (model #KSC5251)?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Oct 05, 2010 | KitchenAid Superba Architect KSCS25INSS...
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not getting water. Everything else seems to work fine. I can put water manually into the ice maker and get ice. But no water from the line. It is a KSRS251 superbra side by side Kitchenaid model.
You will have to remove the icemaker and look inside the water fill tube at the rear wall of the freezer.
The water line may be frozen closed.
If so,take a hair dryer and thaw it out.
This manual will explain other test to complete.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Nov 09, 2009 | KitchenAid KSRS25IL Side by Side...
Kitchenaid superbra 24 oven
select clean on the control panel and set stop time then push start
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superbra Freezer Settings model ksrs25qf00
21/2,will give you 0 to 8 degrees,the hiher you set the dial the cooler it gets in the freezer-mike
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Despenser Just Humms
  • the motor could be bad, the humming sound is a sign of that.
  • but i would suggest taking the auger out and make sure nothing is jamming it in anyway.
  • remove all of the ice cubes, ice buildup, or anything else that is not supposed to be in or around there.
  • it is worth a try before you start spending money. :)
Jul 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
Constant Humm / Buzz but Works OK
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Dec 21, 2006 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
70 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
