Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F 50 error message
Machine starts normally.. once the first spin cycle starts the error pops up and the machine stops. I followed the manual instructions to pause then restart with same results. The drain and spin cylce doesnt work either. Clothes are left sopping wet. Seems as if the machine won't spin.
  • JUPPAN Jan 06, 2009
    I have the same problem, if I ask it to just rinse and spin it's O.K., but it won't do the hole process by itself.
My washer is flashing f 51
Posted on Aug 29, 2008
Assistance with rectifying as to why my LG top loader stops once it gets to the spin cycle. Can someone assist?
Before the washer can start to spin it needs to drain the water from the drum. By you having to drain the water from the machine indicates that the drain operation is not happening. This in the majority of the cases is a bad drain motor.
Aug 26, 2015 | LG Washing Machines
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
F02/Sud error message fabric softner will not dispense
The pressure switch is sensing that there is still water in the unit,it sits at the top of machine under the top cover,it is round and usually red in color remove the hose/tube from it and blow through it to make sure it is clear,you can also remove the switch itself and lightly blow into it you will hear a couple of clicks put it back together and give it a shot..
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin Cycle
I just replaced my second motor control board because of the same problem. Mine starts to spin but never reaches speed and stops, then it repeats. It can do this for hours. I think we are overloading the machine washing area rugs. The fuses are OK on both failed boards and nothing is burned and all caps look normal. At $150 a pop, I would rather replace some components if I knew which ones. For a quick fix, the new board worked for me.
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
374 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
