After washing is done ater is not draning. How to fix it ?
  • 108 Answers
Chances are pump is blocked have you tried putting it on spin? take the back off right down the bottom of the bowl you should see the pump should be a lid on it that you can unscrew somtimes coins or chains get stuck in it it is an ezy fix if thats the prob
Posted on Apr 11, 2011
Tip
How to get your washer to work when it does not spin or drane
go to the fillter at the front of the mashine and turn it to open, make sure mashine is turned off.put a bowl or plenty of towels down let the water drane out then clean the filter out.put it back in close it and away you go
on Feb 16, 2010 | Washing Machines
Battery is being drained. Replaced starter first for first problem then replaced alternater due to battery draning. Had all systems check done shows a drain, where and what to do next?
?sure battery is good could pull fuse for clock .radio.ex. until it stop the drain how quick does it drain did you have anything done just before this started?
Mar 11, 2010 | 1994 Ford Escort
Where is the drane cooling system drane plug
Lower left corner of radiator, you may need to turn and pull at the same time, turn left, be easy, dont break it off.
Nov 04, 2009 | 2003 GMC Sierra 1500
My washing machine will not hold water
Make sure your drain is at the proper height. Here is a photo for reference. The water draining straight thru can be caused by this. If this is not the problem, please let me know. Hope this helped and best wishes.
Sep 13, 2009 | Washing Machines
My washer stops after the wash cycle. not draning or spinning
CHECK THE RUBBER DRIVE BELT FOR THE PUMP UNDER THE WASHING MACHINE
May 09, 2009 | Washing Machines
Water
you need a cold or hot water valve. one of them is not closing all the way after the cycle is done. turn off cold water at wall, if no water appears you know its the cold water valve. if water does apear you know its the hot water valve
Nov 16, 2007 | Bosch WFMC 3200 Front Load Washer
Dishwasher dose not drane
YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
May 02, 2007 | Hotpoint 24 in. DF55 Free-standing...
Hoover washing machine (commodore 5.0 kg)
this is either a belt slip or a squeeling bearing ater seal, if it is not the belt then try doing a boil wash, this often resolves the problem. Regards Advisor
Jan 30, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
