Question about Hitachi CLU-4324UG Remote Control
One of the buttons does not work. The number, volume, input buttons work, but the select button does not. Thanks, Michelle
  • 108 Answers
More then likly it will be motherboard for your remote if you can take it apart and see if can a break in the curcuitry if so scrape it back to expose copper then repair using liquidwire about 10 bucks from most electronic stores its just a glue very ezy to use works like solder but is a glue if no break in curcuitry then try looking at rubbers on the back of the buttons hope this helps
Posted on Apr 11, 2011
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Under settings all it will show me is language there is no volumn setting-my sound is not working correctly
hope this helps
Oct 17, 2012 | Apple iPod nano 4th Generation
Cant get volumne to work and the power button is stuck. any suggestions. thanks.
Fix the stuck volume button as it may be invoking an input signal, precluding the volume input.
Jun 03, 2011 | Televison & Video
How do you record to channels 9-24 ?
Press the select button for channel 9 (or any channel you're wanting to record on) and hold it down. While holding down the select button of your chose, press one of the "input (A-H)" buttons as you would if you were toggling on a regular computer. The Input button you select will become your new available track to record on. Be sure that the input button you select has a mic or something connected to it and its volume is adjusted to control your input level.
Sid from the SBL Network, Inc. - SoundLab
Apr 30, 2011 | Tascam 2488 Portastudio Multitrack...
How do u change av on tv withoute remote
Directly on the TV there should be a button marked AV/Source/Input. That would be the button to press till you reach the desired input.
Thanks
Dustin
Jan 04, 2011 | Hisense Televison & Video
Hi, I have a crown digital timer model number cra8442. I have lost the instructions and cannot remember how to set the time. Can you help? Many thanks Michelle
Hi, push and hold the 'yes' button until the day flashes, select day with v ^ buttons. Press 'yes' again to set hour. repeat for minutes etc.
good luck
Dec 22, 2010 | Vacuums
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Remotes do not work and front panel will not allow me to select input or change volume
I figured it out. It is, in fact, the front panel board. Disconnecting it sloves all issues. A contact in one of the tact switches must be stuck or giving an abnormal resistance value to the system. Once disconnected, the remote works correctly. I'd rather replace the entire board than try fixing/replacing a tact button only to have another fail in the future. I've heard this has also been an issue with the power button.
Oct 13, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Hitachi CLU-4324UG Remote Control Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
