My toshiba HD A-30 dvd player is no longer responding to the remote control that came with it. i've replaced the batteries and still it doesn't work. any suggestions?
    Novelist:
  • 159 Answers
Hi, Yes I suggest repairing the remote. It is not very difficult. rmeotes have just a few thing that " can " go wrong due to their nature. Almost all problems come from some form of what';s classified as abuse ( most of the time we think of it as normal wear and tear ) Not a big problem. If you drop your remote It may shake loose the inner workings of what's called a " ceramic filter "-once that happens the remote will rattle from that area but will not operate. If you spill almost anything on the keypad area it is possible to freeze up the remote by having no contact with the buttons and motherboard. and thirdly-if the remote was ever stored for an extended amount of time with batteries intalled they may have leaked leaving behind a greenish residue on " Battery terminals " which can impede power. cleaning can solve that. Those are what afflict the common remote. Dis-assembly is acheived by unscrewing the case probably from inside the battery compartment somewhere-then some "Gentle " prying at the seams and they "pop" open pretty readily. cleaning the keypad just takes some rubbing alcohol from some where, " Prep Pads " work well for this clean the backside of the key's-and shiny little maze like patterns which are the contacts. then gently dry and if after that if still not working check for ceramic filter ( it will be a pastel color-green, blue, orange ) it may resemble a smaller and squarer chiclet. it will be connected to " circuit board with 2 leads, if it has any rattle it will need replacing. Most of the time they are interghangeable from one remote to the next. that about covers what could be wrong, good luck I hope this helped, Prodzilla
Posted on Apr 11, 2011
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
Just bought a Toshiba refurbished DVD/VCR player. The remote doesn't work at all. I've doublechecked the NEW batteries and tried a tip of pushing EVERY button with the batteries out. Any ideas
1) the batteries will be the same type and full charged
2) clean the contacts battery from dirty, dust, oxide or corrosion
3) retight the spring contacts battery with pliers for a GOOD contacts
4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Toshiba Televison & Video
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
Toshiba Tv remote control
I NEED THE CODEOR CODES THAT TOSHIBA DVD-HD A30KU TU USE AND RECCEIVER ONKOY
Jun 09, 2008 | Toshiba HD-A30 HD-DVD Player
Toshiba hd dvd remote codes
you can get the users manual online on toshiba's website.
Mar 08, 2008 | Toshiba HD-A20
HD-XA1's door won't open
how do i connect my dvd to my tv with scart leads
Jan 14, 2008 | Toshiba HD-XA1 DVD Player
Toshiba hd dvd A20 remote codes
i am having the same problem with the HD-A2KU hd dvd player not recognizing any of the codes. it seems that the dvd player does recognize the codes but will not control the player. when i click the on off button the dvd player changes to a word but does not turn it off or control it.
Oct 30, 2007 | Toshiba HD-A20
Televison & Video Logo
Top Televison & Video Experts
