Question about Uniden BC370CRS Base Scanner
I cannot get any police scanning from my bc370crs---is that normal not to hear anything for long period of times
    President:
  • 2,761 Answers
Yes, especially since your area may have switched to trunked/digital systems that would leave only a few working frequencies available to your BC370CRS. Check www.RadioReference.com for a comprehensive database of active frequencies in your area.
Bill B.
Listening in since the 60's
Posted on Apr 11, 2011
I was given a uniden police scanner and I need to know the frequencies and how to get the static out. . Thank you . Rhonda Hansen
First thing to try is to change the "squelch" setting. If you squelch is set wrong, you will hear static all the time and the scanner may not scan. Turn the squelch until you no longer hear the static and the scanner scans.
Nov 07, 2014 | Radio Communications
Cannot get police on my bc370crs but get fire and rescue do i need digital scanner
Hello david,
Welcome to FixYa.
My name is John. I will be assisting you with your issue today.
I think you already have a digital scanner. Here is a link to help you
with a manual that's all you need. http://www.uniden.com/pdf/bc370crsom.pdf
You can get the frequencies for your state here. www.RadioReference.com
I hope that this was very helpful to you.
Thanks for choosing FixYa.
John
Feb 05, 2011 | Uniden BC370CRS Base Scanner
What are police radio frequencies for Willard, ohio 44890
For a comprehensive database of active frequencies in your area, visit:
Bill B.
Dec 29, 2010 | Uniden BC370CRS Base Scanner
How to set up a uniden bc370crs scanner
Your best course is to follow the simple instructions in the factory manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC370CRSom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B.
Dec 28, 2010 | Uniden BC370CRS Base Scanner
Can not get our police channels to scan, the fire and ambulance work
If your scanner previously picked up your local police communications, it's possible that their system has been upgraded to a new trunked radio system - a system that your BC370CRS is not capable of monitoring. For a comprehensive database of active frequencies and systems in your area, visit:
Jan 10, 2010 | Uniden BC370CRS Base Scanner
How to progam a bearcat police scaner
To program known frequencies into your BC370CRS:
- Slide the MODE switch to the "Scanner" position.
- Press and hold the POWER button momentarily to power the scanner ON.
- Turn the SQUELCH knob slowly to the left until scanning stops and you hear a hissing noise.
- Turn the Volume level down to a comfortable level.
- Turn the SQUELCH knob to the right - slowly, until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 158.075).
- Press E (PGM).
You've just programmed channel 01. To contimue programming, press the up arrow to advance to channel 02, press HOLD, enter your frequency, etc.
When you're finished programming, press the SCAN key.
Need the manual for your scanner? You can download and print it here:
Please contact me if you have any further scanner questions.
BillB
Jan 08, 2010 | Uniden BC370CRS Base Scanner
How do you set the scanner to your local police or
First you need to know what frequencies are in use in your area. For a comprehensive database, visit:
To enter (program) a frequency for future scanning:
- Slide the MODE switch to Scanner
- Press the E (PGM) key. This will turn on the PGM indicator at the top right of the display.
- Press the UP or DOWN arrow (above the SCAN and HOLD keys) to advance to the desired channel, OR enter the channel number using the keypad.
- Press HOLD
- Enter the frequency, including the decimal point (e.g. 155.67).
- To continue programming, use the UP or down key to advance OR enter a channel number, press HOLD, and continue programming as above.
When you're finished programming, press HOLD or SCAN.
I hope this helps. I have a BC370CRS on my desk, and I found that the programming is fairly simple -- once I got used to it.
NOTE: The BC370CRS will NOT work with trunked or digital radio systems. If these are in use in your area you will need a different scanner to listen in.
Dec 25, 2009 | Uniden BC370CRS Base Scanner
My owner's manual for Uniden BC370CRS is NO help! Program help!
Find the frequency you would like to store, press "E" pgm, then select the bank you would like to store it in (1 thru 10) by using arrow up or down then hit "E" again and it will save it in that bank. When you hit scan this will scan all your saved frequencies.
For scanning all frequencies not saved, move the switch to scanner and arrow up or down, when you find one you would like to save follow the process above.
Dec 26, 2008 | Uniden BC370CRS Base Scanner
I cannot get any stations to come in on my scanner for police or fire and emergency frequency.
check the antenna connections first,does it scan but not stop? or does it stop but you hear nothing?If it stops and you hear nothing try the headphone jack and see if you can hear anything there, if so its the speaker or audio amplifier. if it scans but does not stop try removeing the antenna and putting it back on to see if it has a good connection.
Dec 10, 2008 | Uniden BC340CRS Base Scanner
Uniden BC370CRS Base Scanner Logo
223 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
