Question about HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
My Hp ac adapter would get really hot and one day it just stoped charging my laptop. I went to the store to get a universal adapter and that isn't working. is it something inside the computer. if so is there a way i can fix it.
  • seizen Aug 07, 2008
    Nope still no power. i don't think the battery is the problem, because i was on my computer before it died because there was no charge getting to the battery.
    Master:
  • 397 Answers
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Posted on Aug 07, 2008
Can i charge my hp pavillion dv1000 from my desktop through a usb port?
NO! You will damage one or both computers. You really need to repair the laptop or ac adapter to correct the charging problem. The HP dv 1000 as well as the other HP entertainment laptops have had a lot of problems. Not charging just one of them. I would strongly suggest a professional repair of this laptop.
Apr 01, 2011 | Computers & Internet
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
HP Pavillion power link blinks
aa505 -
I can almost guarantee you this is an issue with the power jack on the laptop's motherboard. Even though it may not appear to be loose, its most likely the solder connection on the motherboard has broken, only allowing intermittent connection when the laptop is in /just/ the right position.
It'd be best to get this looked at sooner rather than later, preferrably if the computer is still under warranty. The connection will steadily decline, until the laptop is unusable.
Otherwise, let me know if you want to get rid of the system! I have a system, almost exactly the same model, that I need parts for!
Hope this helps!
-thinstatic
Jun 12, 2008 | HP Pavilion dv1000 Notebook
Battery won't charge
sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Mar 22, 2008 | HP Pavilion dv1000 Notebook
How do you charge a DV 1000 hp pavillion laptop?
plug in the power adapter, make sure the battery is installed firmly, let it run for 6 to 10 hours..hopefully the battery, installed under the unit, will be fresh enough to accept a recharge cycle.
got backup for that computer?
Feb 19, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
546 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
