The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
You might have been able to find a replacement seal for the top but if the bottom is leaking that means the seal is gone there as well and that means replacing the container. The real problem is finding any of these. And when you do the cost is going to be as much as a new unit.
I'm afraid the best advice is to replace the entire unit. The only thing is to make sure you buy a quality unit if you want to get any useful life out of them. A cheap unit is going to start leaking within a year or two (about 30 seconds after the warranty runs out) a good unit will give you hopefully another 5-10 years of use.Might cost more now but you won;t have to replace it that quickly either.
Hi. I've checked online with Braun and there's no Owners Manual available on their website anymore. I own the same model (rebadged) and find it excellent.
The best I can offer you is a Service Diagram with an exploded view of parts.
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
REMOVE THE 4 BOTTOM SCREWS AND TRY IT AGAIN. YOU CAN SEE THE SEAM AROUND THE JUICER WHERE IT SEPARATES. YOU CAN GET THE SWITCH FROM WARING AT 800 492 7464. MINE IS FROM 1990 AND RUNS LIKE NEW. DO ALL MY OWN REPAIRS.
