Question about HP OfficeJet Pro K5400dn Photo Printer
K5400 warning lights indicated print head problems. I have cleaned the print heads and reinstalled them and I am back in business but now it's doing a test print on every occasion.
    Guru:
  • 89 Answers
Try doing an alignment with the printheads.
You can also try changing the inks,if that solves the problem eventhough old inks are stil not empty,contacts might be the issue on old inks which causes error blinking lights which is an indication of printhead rejection.
Method one: Clean printheads in Solution Center
  1. Make sure the printer is loaded with unused white paper.
  2. In HP Solution Center , click Settings , and then click Printer Toolbox .
  3. Select the Services tab, and then click Clean Printheads .
Method two: Clean printheads from the control panel
  2. Press and hold the Power button
  3. Press the Cancel button two times.
  4. Press the Resume button one time.
  5. Release the Power button
    Cleaning the printheads takes a few minutes, and when it completes, a page prints.
Method one: Calibrate linefeed in Solution Center
  2. Open HP Solution Center , then click Settings , then Printer Toolbox .
  3. Select the Services tab.
  4. Click Calibrate Linefeed .
  5. An Advance Linefeed Calibration window opens. Click OK .
  6. After calibration, print another PQ Diagnostic. If there are still dark lines or white gaps in Test Pattern 3, the printer must be serviced.
Method two: Calibrate linefeed from the control panel
  1. Press and hold the Power button
  2. Press the Cancel button fourteen times.
  3. Press the Resume button six times.
  4. Release the Power button
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Posted on Apr 11, 2011
    Guru:
  • 352 Answers
Hello. Follow the link below and select your operating system. There is a program from HP called the toolbox, Download it and install that. There should be a re-set tool or a setting to help you out.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=2511752&lang=en&cc=us&prodTypeId=18972&prodSeriesId=2511747&taskId=135
I hope this helps
Regards GM
My colours are not aligned anymore.
Go to printer menu, in services select clean print head nozzles, then perform align print heads,once align completed check for the print waht you checked earlier...
Feb 01, 2012 | HP Officejet Pro K5400 All-In-One InkJet...
Black ink not printing properly on HP Officejet Pro K5400. It's a new cartridge, have tried another cartridge too but same problem.
The print head may be blocked.
Run the cleaning cycle a few times on the machine.
This can be done through the software drivers loaded on your computer.
If this does not help, you will need to replace the black print head.
Feb 14, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
Head error after replkad
Remove the print heads and very gently clean the area on the printer and print head where the electrical contacts are. Do this with a Q-tip lightly moistened with distilled water. Be sure all surfaces are clean and dry before reinstalling the print head. If that doesn't work then your replacement print head is bad and you should return it to where you bought it or contact HP.
Jun 09, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Feb 12, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
I960 resume light flashes yellow 5 times 1 green
Five yellow flashes indicate that the printer doesn't recognize the print head, or thinks that the wrong print head is installed. You can try to remedy this by opening the cover, removing the ink tanks, then removing the print head (lift the locking lever). Check that the copper contacts on the back of the print head are clean, then reinsert the print head, lock it in, and reinstall the ink tanks. If you still have the error indication, the print head may be bad and need replacing. Contact Canon for your options on this.
Feb 05, 2010 | Canon Office Equipment & Supplies
HP k5400 KY printhead always reports bad on Monday morning
Remove the Printhead and clean the contacts on the back of the printhead and also in the where the printhead mounts.
Try leaving the printer turned on over the weekend as the fault maybe caused by the ink drying out.
Jun 22, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Hp officejet, pro k5400 printer,when printing i get lines top to bottom on print,about 1 inch apart,tryed print head cleaning,changed the cartridges .need help ,top to bottom,only on...
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Jun 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
My KY yellow light is blinking. What should I do?
The k5400 is not recognizing that the ink cartridge is installed. Clean the contacts on the back of the ink cartridge and also the contacts in the K5400 printer. I always use 91% isopropyl alcohol, Hp says to use distilled water. Do let the contacts completely dry before reinstalling.
Feb 24, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Print head noi installed
Sometime the problem is the cartridge it self....And sometime it's the cartridge beside the one that is always warning.
Mar 25, 2008 | Office Equipment & Supplies
HP OfficeJet Pro K5400dn Photo Printer Logo
444 people viewed this question
Ben Johnson
