Question about M-Audio Studiophile AV 40 Monitor Studio Active
Right speaker quit working after 6 months - M-Audio Studiophile AV 40 Monitor Studio Active
  • 24 Answers
Swop the speakers overs this will tell you weather it is the speaker or the amp. if the speaker then it has blown or the crossover unit has blown. the crossover unit splits the signal to the bass /middle and top frequencies. if you want an easy way out after you have checked the speakers/amp by swoping them just go and buy a new pair but make the sure they are the same impedance as the old pair as you can easily damage the amp
Posted on Apr 11, 2011
Speaker not working
try switching the leads on each speaker. if sound transfers then you have a bad channel. if you get no sound, then your speaker is bad.
Mar 08, 2014 | Line 6 Flextone III Plus Guitar Amplifier
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
Peavey sp2 pa speakers quit working
Ok,
First of all i need some more information, such the power amp you've hooked to them rating in watts and please specify if you are not getting sound from tweeter or 15" BW speaker or both of them, this way i can improve accuracy helping you out.
Feb 03, 2013 | Peavey SP2 PA Passive Speaker
I have a Peavey PV 115 Speaker...The horn works and the fuses are good ..The wiring looks and feel tight BUT the 15" speaker will not work...Any ideas ???
Check the resistance across the woofer connection points. Using an ohmmeter, you should se around 6 to 8 ohms. If there is no continuity, you have a blown speaker.
Jun 25, 2011 | Peavey PV 115 Speaker PA Passive
Just bought a pair of used Beringers Truth b2031a monitors. one of which doesnt work anymore at all... opened the back of it (took those 6 screws out) and saw that the power connection has been cut of......
Here is the service manual schematics for your speakers:
http://elektrotanya.com/behringer_b2031.pdf/download.html
Scroll doen to "get manual" and click on it to download the manual... Do not click on the other downloads at the site, they are for viewers you don't need.
Take the schematics to a COMPETENT electronic service technician to get units repaired. You obviously bought units that had been hacked before...
Jun 21, 2011 | Behringer Truth B2031a 225-watt Powered...
I want to order a new volume pot for my Eurolive B215A powered speaker directly from Behringer, then fit it myself. Who do I contact to order the part?
Lots of luck. Behringer no longer sells direct. Fullcompass.com is their parts distributor. If they don't have it in stock, it takes months... I have had an order in for 6 months now. The procedure is you call Behringer at 1-425-672-0816 to get a part number and an incident type number. Then call Fullcompass and order the part at 1-800-356-5844 and tell them you need Behringer part. IF they have it in stock, then you are lucky.
May 18, 2011 | Behringer PA speaker Eurolive B212A
M-audio av20 right speaker has no sound coming out of it at all...
To troubleshoot the problem start with the bit that is working - the left speaker.
  1. Unplug the input leads on the back of the left speaker and swap them round.
  2. If sound now comes out of right speaker and not the left the problem is with your sound source (computer, IPOD or whatever) or the connecting cable is faulty.
  3. If there is still no sound from the right speaker try turning the volume control knob up and down quickly several times - does this produce any sound from the right speaker? Sometimes the electrical contacts get dirty and this can help clean them.
  4. Turn the speakers off using the volume control knob. Disconnect the speaker wire for the right speaker from the OUTPUT on the left speaker (push the red and black tabs downwards and gently pull the wires out. Find a small 1.5 volt battery (an AA or AAA size will do nicely) and touch the bare ends of the speaker wire briefly on the battery terminals. If you hear a slight crackling sound the wire and the speaker are okay and the problem is in the amplifier, which will need repair or replacement - not a job for an amateur.
  5. If you don't get any sound from the battery test find another piece of speaker wire (any piece of 2 core cable with bare ends will do for testing) and repeat the battery test. If you get sound then replace the speaker wire. If not remove the speaker wire again and go to next step.
  6. Lay the speaker face downwards and carefully unscrew the back panel (don't do this if it is still under manufacturers warranty - take it back for repair or replacement). Lift the back panel off carefully and slowly taking care not to pull the connecting wires inside the cabinet, which will probably be quite short. You may have to settle for just rotating the back panel slightly so that you can see inside if the wires are too short to do otherwise.
  7. Use sticky tape to tightly attach the bare ends of the speaker wires to the terminals of the battery. Touch the loose ends of the speaker wires on the two metal terminals where the internal wires are joined onto the back of the big loudspeaker cone. If this produces a crackling sound it is the internal wiring in the cabinet that needs re-soldering. Otherwise the loudspeaker unit has failed and will need replacement.
Jan 29, 2011 | M-Audio Avid Maudio 99005226600...
2 draw hole not right and screws or nails? to
How old is the harmonica? They wear out over the years. A Guy that I know that plays blues harp replaces his every 4-6 months.
Oct 11, 2009 | Music
I don't know....
As you know, when you plug in your headphones, the amplifier cuts the sound to the external speaker, routing the signal through your headphones instead.
When you accidentally pulled the headphone plug from the jack, it apparently damaged the jack, which has the relay attached that routes the sound to your headphones.
Replace the jack, and everything may be OK. I say may be, because the jack is attached to a circuit board in these line 6 ampllifiers, and if you have damaged the circuit board, you will have to send it to line 6 to be repaired.
The downside is if it is not under warranty, it is an out of pocket expense, and Line 6 will not even give an approximation on how much a fix will cost. I have gone through it with Line 6 in the past, so I am very aware of the procedure. It is also a limited warranty, and they may not cover this particular damage.
However, if you are straight with them and they feel obliging, they may fix it under the warranty, if it is still active on your amp.
I had a spider 2 x 12, which was switching between amp models by itself, and they told me that because it was not under warranty, that I might want to consider NOT sending it to them, and just buying another amp. I didn't like that advice, because they seemed as though they didn't care about retaining my business.
Now, something to consider is taking it to a reputable amp repair shop (preferably one that is Line 6 authorized), and see what they can do. Maybe your clip is just bent, not allowing it to spring back from the contact switch that cuts off the main speaker. It could be a very inexpensive fix, but you need to have a shop actually take a look at it up close and personal.
Good luck. I, for the most part, enjoy Line 6 products, and their excellent distortions. Just remember, their amps tend to have a LOT of problems. You can find sites that list many many dissatisfied Line 6 amp owners. All that electronics (on board effects, soft buttons and switches, etc.,) make them vulnerable.
Now I mainly use my old reliable Marshall 1/2 stack with my Line 6 pod, as well as quite a few other pedals.
You would be amazed by the fact that you can still get pretty good money for a broken line 6 amp, maybe get something with less bells and whistles to break, and go with off-board effects pedals and processors.
Please excuse me for adding my own opinions, I am quite well versed in this type of advice having grown up in a luthier / guitar shop and have been playing for 38 years.
Good luck with everything, and if all goes right, adn it is just bent, it may cost you as little as a few dollars to fix. I'll keep my fingers crossed for you.
Thank you for using FixYa.
Sep 09, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
M-Audio Studiophile AV 40 Monitor Studio Active Logo
319 people viewed this question
Top M-Audio Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a M-Audio Music Expert? Answer questions, earn points and help others
