Question about Lincoln Conveyor Oven - 1133-000-A
Our oven keeps shuting down, it cools down to about 290 degrees and then turns back on.
  • dmpittman59 Apr 11, 2011
    Thank you very much for the information. We are going to try to fix it today.
  • Lincoln Master
  • 5,370 Answers
The internal temperature is heating, but the internal blower fan is not cooling the thermocouple/ heating element.And due to this the heat exceeds the level and conveyor oven shuts down, but as soon as the thermocouple cools down, the unit comes ON.The same cycle continues.In your case, the internal blower fan needs to be checked.Try cleaning the fan and then see, if that makes any difference in problem.If its same as before, then try connecting external fan and see, if that is helping. 1.Make sure the ventilation Canopy Fan (This is not a part of the oven)is running.
2. Allow at least 10" gap between the back of the oven and the wall.
3. You can install a boster fan at the back of the oven to extract the heat from the main fan,This should help.Also if fan checked out, ok, then it can be heating elements, they must be getting overheated, then set temperature.Get the element connections checked./ --------- also if internal motor is getting weak or vent air is getting blocked, then inside heat increases and oven shuts off.so check the motor and clean the ventilations.This will help.thanks.Helpmech.
Posted on Apr 11, 2011
Whirlpool super capacity 465
Seems the thermostat is malfunctioning...thus when baking at 500..thats quite high...it keeps getting hotter past that point to where the oven thinks its in self cleaning mode. Also seems like the problem because when it cools down your allowed to use it again. There is no way to test it with an ohmmeter. Just remove and replace.
Nov 30, 2013 | Ovens
Lock would not open after cleaning process has been canceled, oven is still hot
Don't open or try to open the oven door, until it has cooled down completely. The oven heats to a very hot temperature, usually 800 to 900 degrees. The door locks itself once it gets to a certain temperature, and will not allow the door to be opened until it cools below a certain temperature. On some units, this can take hours to cool down enough to unlock. If you try to force it before the cooldown is complete, it usually results in a repair call. If it still will not unlock when it is cool, turn your power to the oven off for 20 minutes, then turn on and reset your oven controls. Sometimes you have to put the oven back into the self-cleaning cycle, and then cancel it immediately to cycle the oven door lock. If it still won't unlock, call a repair company out to service this. Good Luck, Appliance Specialists
Jan 19, 2010 | Ovens
Keeps going off when above 180 degrees, then back on again after 10-15 minutes ?!
Hi.
Without knowing your exact make and model I can only guess that your console cooling fan (sits at the top back of your oven) has failed. This is used to keep the the clock and controls from overheating. If it failes then a safety switch will activate and turn everything off in your cooker. when it cools down it will remake the contact and then switch everything back on again.
Hope this helps
Aardvark Repairs
Nov 15, 2009 | AEG B1180-4 Electric Single Oven
Duke Convection Oven won't heat past 250 degrees
Why should the cooker burn that hot, when you can cook most things at a max 220Celsius
Sep 27, 2009 | Duke 59-E4Z Electric Single Oven
I set oven to 350 and it only heats to 290 degrees and it takes a long time to even get to 290 degrees.
THE THERMOSTAT OR YOUR ELEMENT IS GETTING HOT ON ONESIDE YOU R BEST BET IS TO CALL SEARS THEY WILL COME OUT FOR$75.00 AND GIVE YOU A TOTAL EVALUATION .
Jul 08, 2009 | Ovens
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Dec 30, 2008 | Maytag CWE4800A Electric Single Oven
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Oven shuts down
My mother-in-law's oven was doing the same thing. At first it was actually turning completely off which led me to think it was a loose connection on the circuit board. That turned out to be exactly what it was. I had to dismantle the front of the oven, remove the circuit board, and resolder the connections. The first time I did this I must have missed a few bad joints and that's when it started doing what you described (shuting off and showing lock door). I pulled it back apart and found a few more bad solder joints which I fixed; so far so good. This is of course one of those "don't try this at home" fixes but it least lets you know what is causing the problem.
Nov 09, 2006 | Kenmore 40161 / 40169 Electric Single Oven
Lincoln Conveyor Oven - 1133-000-A Logo
244 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
