Question about Kenmore 600 6965 Electric Dryer
Color code for dryer - Kenmore 600 6965 Electric Dryer
  • 8,197 Answers
MAy I ask what color code you are talking about
Posted on Apr 10, 2011
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
De 407 maytag dryer how do i find a wiring diagram
the Maytag dryers would have the diagram either INSIDE the control panel, OR on the back of the control panel. Neither are color coded as there never was a color coded diagram ever printed. The diagrams do list the color of wires and show where they start and terminate. That is all a service tech would require to troubleshoot. If the diagram has been removed, you could try an online search.
Jul 03, 2014 | Frigidaire GLER341A Electric Dryer
Sparks coming out the back of dryer where plug is at dryer not wall
Sounds like the wires are arching. My Questions is this a news set up? First thing unplug it before doing anything. Don't even touch the dryer before unplugging it. Then look at the back of dryer are the wires loose tighten them to the terminals. If they are not loose not maybe they are wired wrong make sure your color code matches up. What are your color codes? You can search your dryer model and come up with a diagram. That is all I can do without seeing it in person or knowing the model.
Jul 17, 2013 | Dryers
Need wire diagram for 4 wire cord [color code[
Here is a tip that will help you with that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 17, 2010 | Dryers
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
Need new four prong pigtail. wires on dryer are not color coded.
The following link explains how to connect a 4-prong appliance cord to your dryer:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
This is for United States Standard wiring code. If you reside outside the US, please let me know.
In a nutshell the color coding is as follows:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
Facing the dryer from the rear, remove the cover over the terminal block. If the wires at the temrinal block are not color coded, the outer two wires (L and R) are your hot leads. The center wire will be neutral. The ground wire gets grounded to the equipment cabinet on a ground lug. Make sure you do not ground the neutral wire.
If you have questions about this repair, please ask. I hope you find this information helpful.
Aug 20, 2009 | Dryers
How to hook up a cord to the maytag neptune dryer color codes
these are single phase so just copy red to red black to black white to white and green is ground
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Amana dryer, changing out the electrical plug from 3 to 4 prong
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Jan 27, 2009 | Dryers
Kenmore 600 6965 Electric Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
