Question about KLH HT-9930 System
One of the clips on the back of my klh-HT-9930 speakers that holds the speaker wire in place broke off. Is there a way I can fix it or get a replacement part?
  • 24 Answers
You can find replacements from radio shack or maplins. you may like to try a stronger type as the ones shown tend to be a little weak
Posted on Apr 11, 2011
I have a pair of KLH AV5001 speakers and I have them hooked up, there is sound but it's distorted and there's zero base, an instruction manual or any advice would be great, thank you.
Without knowing what they're hooked up too.. SOUNDS like your uder powering them, OR over powering them. Look at the back of the speakers the wattage is what your looking for, look at your amp, example: 1000w speaker running on 50w amp = not good.
Jul 05, 2016 | KLH Audio Players & Recorders
My KLH powered sub maks e a humming sound when i plug it in but it only hums when the speaker is hooked up i tried others but did the same eventually speaker started smoking would wrong fuse do that
Wrap a wire around the outside Metal of your rca jack in back of your radio and ground the other end of that wire to the back of your radio and the noise goes away
May 09, 2015 | KLH Audio Players & Recorders
I have a klh home theater speakers with a subwoofer the sub work but when i hook up speakers no sound comes out?
The sub works but the speakers don't? Do you hook up the speakers to the subwoofer output "loop"? This is a circuit issue when it works and stops working. I have the same issue so I wound up joining the wires that go to the sub and the wires that go to the speaker together and place those connections into the sub. The sub works, the satellite speaker works and the impedance load is no issue for my system. Confused? Simply run your neg/pos wire to the sub and where it connects to the sub, run another cable to the speaker (pos to pos., neg to neg).
The only way to repair it would be to deal with component level repair. Although I have the experience, it is too petty and it works fine the way it is.
Apr 12, 2011 | KLH ASW10-120 Subwoofer
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
KLH Model 09 speakers
speaker terminal is present in radio shack if you have technical background you can replace it easy otherwise you pass it to service technician.
Jul 07, 2008 | Audio Players & Recorders
KLH RS100 Receiver
Swap the left and right speakers, if the problem transfers, then the left channel is out. Theres 5 amplifier sections in this receiver and that one would be defective. A component troubleshooting technician would need to fix it.
May 10, 2008 | KLH R5100 Receiver
Klh subwoofer asw80-80
Unfortunatly it is due to the wiring within the house. Short of buying an apc back up which will regulate the power there is not a powerstrip that will stop this. I used to have the same problem
Feb 18, 2008 | KLH ASW10-120 Subwoofer
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Surrond sound
For Stereo Mode (Front L & R Speaker), you must plug RCA cables (match up red and white) from Output on DVD player to DVD Input on the back of the receiver. Then with speaker wire, run from receiver speaker output (Front Speakers) to designated speaker (make sure + and - match up to both input and output). As for hooking up surround sound, I'm currently trying to figure that one out with just using the L, R and Center. I don' t want wire running all over the place just for rears. Hope this helps
Sep 04, 2007 | KLH R5100 Receiver
KLH HT-9930 System Logo
60 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
