Question about Intermatic 200W Power Pack & 12v Transformer ML200RTW
Timer turns lights on for 2 seconds then shuts off ?????
Timer is malfunctioning, or trippers are worn down and don't fully push the switch over.
See it timer operates on manual override.
Buy new trippers, and/or buy cheap plug-in timer, and then set power pack to override, and plug power pack into cheap timer.
Power Pack uses 107SB189 ON tripper, and 107SB192 OFF tripper
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, links to manuals, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 11, 2011
  • Anonymous Apr 11, 2011
    ML series power packs come with 5-year limited warranty
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Was running a load of towels on auto sensor timer. Heard a pop and the dryer shut off. Sensor light was lit on wet. The dryer will not start under any settings. Sensor lights will flash on sometime,...
If you heard a pop then your belt probably fell off. There is a belt safety switch that wont allow the dryer to turn on if the belt is not attached
Jul 14, 2011 | Kenmore Dryers
Power will not stay on
u have a problem with the convergen ic , and 2 pico fuse on power supply , this repair normally cost about $300
Apr 13, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv turns on. A blue screen appears. Then it shuts down in 20 seconds. The timer light blinks repetedly.
Try this:
1) turn on TV
2) from the remote control ..press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING.
4) press the RESET BUTTON on front of TV.
5) should be good to go!
Jan 15, 2010 | Mitsubishi WD62627 62" HDTV
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Coffee maker timer does not keep the heat plate on after 10 mins.
I was able to fix my little problem. I unplugged my coffe maker and waited 'bout 10 mins for the whole thing to shut down. Once the clock shut off, I reset the time. Secondly, I pressed the on/off button and held it in for 2 seconds until the red light started flashing. I set H to 1 and M to 59(I have never seen this before). anyhoo, afterthat, I set the timer to the exact time I wanted to smell my freshly brewed coffee. This morning, the red light seemed to stay on and kept my coffee nice and hot.
Nov 25, 2008 | Braun AromaDeluxe KF 580 Coffee Maker
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Intermatic 200W Power Pack & 12v Transformer ML200RTW Logo
71 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
