Question about GE JBP82 Electric Kitchen Range
I just bought a used jbp82 and the plug does not fit the house plug in. Its a 3 prong and the stove is a 4 prong. Can this be worked out somehow?
  • 8,197 Answers
You need to change the plug from the old stove to the new stove. It is easy to do. Black on right. white in center, and red on left. The 4th wire is the ground or green. You will not have that one to hook up.
Posted on Apr 10, 2011
I have 3 prong service for double 30 power for stove. The unit has a 4 prong plug. Can I just change out the cord, or does it require rewiring the house?
The unit is set up for a dedicated neutral you will need to have the outlet changed to 4 prong with a neutral
Apr 05, 2015 | Kitchen Ranges
Start button not working
nope 4 prong is for mobile homes and 3 prong is for house. Maybe you wired the cord wrong.
Jan 05, 2014 | GE DPSE810EGWT Electric Dryer
Bought GE Washing Machine but have 4 prong outlet
get in an electrician to fit the correct plug to suit the outlets
May 22, 2017 | GE Washing Machines
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Swich 4 cord to 3 cord plug in
To switch from a 4 prong to a 3 prong. First remove 4 prong cord, save screws you will need them. Look a 3 prong, it will be flat with 3 wires next to each other with metal fittings on the ends. The 2 outside which are hot wires go to the outside screws on the block, and the center which is neutral goes in the center. The only difference in the cords is the 4 prong has a ground, in new construction this is code. You don't need a ground if house is wired for a 3 prong.
Jun 15, 2010 | Roper REX4634KQ Electric Dryer
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
3 prong outlet/4 prong plug
If you bought an electric range , it is a 220 volt range with a BIG plug and can only be used in a 220 volt outlet.
If you can plug a small appliance into that outlet then the outlet is only 110 volts and you need an electrician to run a new 220 line!!!!!!
Was the range you are replacing a gas range??? If so that runs on 110 volts like you TV and toaster and every other small appliance in your house!
If you are not sure what you are doing get a professional to help you!
Every year in the United States thousands of people die buy trying to fix the electrical in their home alone!
BEWARE 220 Volts will shock you! BUT USUALLY will kill you if you touch it!
ngafm
Please rate me on this site before you sign off!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!liance in your house!???????????????
Sep 06, 2008 | Ovens
GE JBP82 Electric Kitchen Range Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
